Register •
FAQ
• Login
It is currently Sun Sep 29, 2024 9:39 am
[ 6 posts ] |
My 77 highboy 400 power steering conversion
Palmer72bronco
Off topic. But want to get rid of whining ford pump on my 77 f250. I know there's a napa part number for early bronco. Any idea of anything links this for the 400.
Tue Apr 22, 2014 6:59 am |
Re: My 77 highboy 400 power steering conversion
Oh Landshark...
Tue Apr 22, 2014 8:28 am |
Saginaw conversion with the jbg or wild horses bracket should work. Not sure of the pump number but you would be better off posting and searching on fordtruckenthusiast.com in the 335 engine section or fullsize bronco 78/79 bronco section.
I have a 400 with the Saginaw on mine in my early bronco and was just doing some research on how to fit the stock ac bracket so I can have the York compressor.
Tue Apr 22, 2014 10:25 am |
A-1 Cardone 206244 is what you are looking for. it's a bolt on sag pump that is for the 78-79 bronco and late 70's pickups. An EB pump wont work unless you get hoses made.
Good luck finding one as they havent been made since like 08 or so.
Tue Apr 22, 2014 1:21 pm |
I think there is a Chevy Saginaw that will work. Want to say from a van? Might be a ford van however. Post up in those other forums they will know.
Rob is right the 206244 is getting very very tough to find remanufactuted
Tue Apr 22, 2014 9:45 pm |
My Saginaw is from an Astro Van with Hydroboost. I only took the res and the pump, bolted it in and ran it. I'm not sure it's the right application tho.
Wed Apr 23, 2014 3:05 am |
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 7 guests |
