Register •
FAQ
• Login
It is currently Sun Sep 29, 2024 5:14 am
[ 5 posts ] |
DanHall
Joined: Fri Jan 17, 2014 2:38 pm Posts: 151 Location: Pueblo, CO
4x4x2 and Hydroboost
Finally got everything installed and plumbed. Bled the steering but still getting some pedal kick back from the hydroboost so I have some more bleeding to do there. Also need to bleed the brakes. But it's running with no apparant leaks and after a couple of belt tightening rounds, no more belt noise.
I am already amazed at the difference in the steering though. Didn't move since I probably have no brakes until they're bled but I can turn the wheels one handed while not moving with the engine at idle. Not something I had experienced in the Bronco before tonight. Pretty danged happy so far.
Wed Apr 23, 2014 8:46 pm |
DanHall
Re: 4x4x2 and Hydroboost
Got the brakes done and in a quick spin around the neigborhood they're equally awesome. It is like a whole new vehicle.
Thu Apr 24, 2014 7:31 pm |
Sweet! Hydroboost was one of my best upgrades.
I'm looking forward to swapping to a 4x4x2 box. I've got all the parts, just need to decide if I want to rebuild/swap things myself or send it off.
Thu Apr 24, 2014 7:47 pm |
DanHall
Thu Apr 24, 2014 8:49 pm |
The "new" brake pedal takes some getting used to.
I had too much front bias in my system. I swapped my F150 calipers for much larger T-bird calipers and pulled the bias back.
Good info on the 4x4x2 swap. Thanks.
Thu Apr 24, 2014 9:54 pm |
[ 5 posts ] |
