www.ColoradoClassicBroncos.com - View topic - Rear gas tank strap
It is currently Sat Sep 28, 2024 11:32 pm
Reply to topic  [ 6 posts ]
 Rear gas tank strap
Post Rear gas tank strap
I'm rebuilding my entire fuel system and the rear gas tank was loose and rubbing on the metal support strap. The tank is ok and doesn't need replacing.
My question is there rubber between the strap? Where, how much,,,anything better?
Anything rubber above the tank?
Metal on metal doesn't seem right.
J.E.
Tue May 06, 2014 4:10 pm
Post Re: Rear gas tank strap
I know that when I removed and repaired mine, there were rubber panels that were meant to go on the corners where the strap met the tank and that was it.
Tue May 06, 2014 4:13 pm
There should also be small rubber sections where the tank bumps up against the frame tabs.
Tue May 06, 2014 5:06 pm
Ok thanks, that helps a lot.
Now I just hope I get one of the old guys at the NAPA counter...
J.E.
Wed May 07, 2014 6:59 pm
Ok, this is embarrassing, but I once found, but cannot now find, the rubber tank bumps between gas tank and body.
I've looked at every vendor and googled it without luck, but I found it easily just a week ago.
Does someone know? This is driving me crazy!
J.E.
Tue May 13, 2014 4:34 pm
I'd use an old cut up playground ball (dodgeball) like all the other bushings and gaskets on my truck.
Tue May 13, 2014 5:14 pm
Users browsing this forum: No registered users and 11 guests
32,370,148 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
