Front end question
Re: Front end question
Postby sbolt19 » Fri Jan 07, 2011 10:10 am
I'm gonna throw this out there, but the thread that HockeyDad started with the drop bracket on the frame makes me, buy the riser for the axle. I have the original trac bar, the riser & a 5.5" lift and everything lines up and is where it should be.
sbolt19
Postby Jesus_man » Mon Jan 10, 2011 10:19 am
Agreed, do not do the drop bracket off the frame. Might be "ok" for a street only, stock size tire rig, but if you do any off-roading, here's what to expect:
Followed by:
Postby hockeydad4-22 » Mon Jan 10, 2011 10:06 pm
sbolt19 wrote:I'm gonna throw this out there, but the thread that HockeyDad started with the drop bracket on the frame makes me, buy the riser for the axle. I have the original trac bar, the riser & a 5.5" lift and everything lines up and is where it should be.
When you are done reading the thread here make sure you read the one over at cb.com too . Wish I had known all this a week sooner...
