It is currently Sun Sep 29, 2024 9:25 am
[ 6 posts ] |
Gremlins in the dash
Having a slight electrical issue and looking for some help with troubleshooting before I tear the dash out.
1. On the instrument cluster, PS turn signal indicator stays illuminated while lights are on.
2. Turn signals go out (fuse pops) after no more than two uses of turn signals. Hazards are unaffected.
3. Gauges do not function. Two instrument cluster voltage regulators are now in the trash after gauges worked for a few seconds and then a barely audible click was heard followed by no gauges working again.
#2 and 3 tell me voltage is above expected in at least two places.
I'd really like to get this figured out before I burn up my other two volt regs.
Thoughts?
Sun May 18, 2014 9:19 pm |
Colorado75bronc
Re: Gremlins in the dash
Sounds like one or multiple shorts to ground, I'll come help you figure it out tomorrow night after work, in the mean time look for chafed or pinched wire, screws run through wiring in the dash, especially in the channel where the majority of the dash harness runs along the lower inside of the dash
Sun May 18, 2014 10:10 pm |
What he said ^
Sun May 18, 2014 10:19 pm |
#1 is a bad ground at the front turn light.
#2 is a short to ground. Possibly inside the turn signal switch.
Mon May 19, 2014 12:03 am |
Gregg
I'd just buy a ton of these. There might be some wiggle room on the $$$ if you buy them in bulk. Rumor has it that Adv Auto is overcharging gullible Bronco owners in the Springs. http://www.wildhorses4x4.com/product/In ... _Regulator
Mon May 19, 2014 8:47 am |
Mon May 19, 2014 10:59 am |
[ 6 posts ] |
