It is currently Mon Sep 30, 2024 1:31 pm
[ 30 posts ] |
Serpentine front dress discussion
Woodscaper
Joined: Fri Nov 19, 2010 11:16 pm Posts: 587 Location: Lakewood/Green Mtn.
serpentine front dress discussion
Anything special about swapping pulley to the stock v-belt on these alternators ?
Wed Jun 11, 2014 1:25 pm |
Re: 3G wiring
Wed Jun 11, 2014 3:44 pm |
Woodscaper
Wed Jun 11, 2014 6:53 pm |
Re: 3G wiring
They should be the same. You'll probably want to figure a double V-belt set up. The higher amperage comes with more drag on the belts. Belt squeal should be expected, especially on start up, even with a double v-belt.
Wed Jun 11, 2014 7:37 pm |
Woodscaper
Re: 3G wiring
Wed Jun 11, 2014 7:49 pm |
Re: 3G wiring
Manufacturers switched to serps when they switched to high amp alternators to deal with the increased power consumption by ECUs and EFI.
Wed Jun 11, 2014 7:53 pm |
Re: 3G wiring
Wed Jun 11, 2014 7:56 pm |
Woodscaper
Re: 3G wiring
Wed Jun 11, 2014 8:13 pm |
Re: 3G wiring
To be careful, just pull everything from the fan back to the driveshafts. Lol
I have a list somewhere. But I'm sure someone will beat me to posting.
Wed Jun 11, 2014 9:03 pm |
Re: 3G wiring
Wed Jun 11, 2014 9:11 pm |
Woodscaper
Re: 3G wiring
Are you kidding me!!! My power steering pump has to go! And a new water pump...Damn man. Better start a new thread (or move half of this one) lol.
Wed Jun 11, 2014 9:41 pm |
Re: 3G wiring
Wed Jun 11, 2014 9:55 pm |
Woodscaper
Re: 3G wiring
Wed Jun 11, 2014 9:58 pm |
Re: Serpentine front dress discussion
Got it. In your case, you'll either want a serpentine front dress from a van, or maybe the van PS pump bracket (they used Saginaw pumps) will work with an explorer dress. Don't know if it will work between the two though.
Wed Jun 11, 2014 10:02 pm |
Woodscaper
Well I will need to go do some digging at the pull yard. Thanks Zach.
Wed Jun 11, 2014 10:07 pm |
Yup.
I see fewer vans here with 5.0s than 5.8s. Explorers run about 3-4 a month, maybe.
I'm going to give the van set up a go on my 5.8.
Wed Jun 11, 2014 10:11 pm |
Woodscaper
Any years better than others??
Wed Jun 11, 2014 10:12 pm |
I really couldn't say for 5.0s. For the 5.8s anything with a "F4TE" part number prefix is supposed to work.
Wed Jun 11, 2014 10:27 pm |
Wed Jun 11, 2014 11:30 pm |
The Explorer serp set up is most desirable because it is short, and fits behind our radiators the easiest. Wild Horses makes a bracket to use the Saginaw pump with the Explorer serp.
Truck serps are a little longer, but it looks like most have made it fit. Trucks used a PS pump that are known to be shitty. You can use a PS bracket from a van (5.0 or 5.8- I think) that fits the Saginaw pump, to the truck serp. You can search this on CB.com and come up with a few threads.
All these serp set ups came from trucks with EFI, so all used electric fuel pumps. The timing chain covers will not accept a mechanical fuel pump. Keep that in mind.
Thu Jun 12, 2014 7:14 am |
Woodscaper
It must be my lucky day. I went to the pull and pay and scored a serp set up. I have to go back for the timing cover and balancer tho, I did not have an impact or a socket big enough.
Thu Jun 12, 2014 3:28 pm |
Be very careful with the timing cover, top two bolt corrode easily and will break off in the heads. Balancer puller is needed, also 3 very long metric bolts, I can't remember their size, maybe 8 or 10?
Thu Jun 12, 2014 7:31 pm |
Woodscaper
Thu Jun 12, 2014 9:07 pm |
Moab Mike
Jeff and I are going Sunday (Father's Day). Last year everything was half price except for admission.
Fri Jun 13, 2014 4:29 am |
Which one are you going to and do you want company? I might be interested.
Fri Jun 13, 2014 6:31 am |
Woodscaper
Re: 3G wiring
Fri Jun 13, 2014 3:53 pm |
What you need is a tech article. http://classicbroncos.com/forums/showth ... p?t=158868Use the Lee adapter only for the PS pump.
Fri Jun 13, 2014 9:44 pm |
Woodscaper
Thank you Phil, that's very helpful. I do have one question, has anybody had a balancer rebalaced? Is it cheaper to buy the aftermarket balancer or have one machined ?? If machined than a referral for a shop that will do it in under a week turnaround? Or do it locally at least?
Sat Jun 21, 2014 12:18 am |
Moab Mike
Sat Jun 21, 2014 7:00 am |
Sat Jun 21, 2014 2:04 pm |
[ 30 posts ] |
Users browsing this forum: Google [Bot] and 5 guests |
