www.ColoradoClassicBroncos.com - View topic - clutch going bad?
It is currently Mon Sep 30, 2024 9:23 am
Reply to topic  [ 12 posts ]
 clutch going bad?
Post clutch going bad?
I'm pretty sure my clutch is toast but I'm lookin for advice on how to verify it's bad or other factors for clutch chatter, abrupt shifts when clutch is let out, tc is popping out. Have a Luk clutch in it but I was running 3.55 gears and 37s before my build. All The SYMPTOM started after build. 4.88 gears, new drive shafts, motor mounts, bushings. Help
Sun Jun 15, 2014 10:58 pm
Post Re: clutch going bad?
Do the high gear test. Put the front of the bronco against a immovable object in high gear, let out the clutch peddle and it should stall if the clutch is good.
Mon Jun 16, 2014 7:55 am
Granny or 1st
Mon Jun 16, 2014 7:59 am
4th
Mon Jun 16, 2014 8:11 am
High gear lol man its too early
Mon Jun 16, 2014 8:19 am
Did not stall rear leaf spring bolts were a Tad loose
Tue Jun 17, 2014 6:35 am
Hmmm one potential problem sorted, now back to the clutch
Tue Jun 17, 2014 7:50 am
I think the chatter wad caused by the spring
Put it in 4th and it stalls.. I'm beginning to believe the throttle linkage is to messed up it not smooth and with the np435 it's all exaggerated.
Tue Jun 17, 2014 7:58 am
Do you have EFI? And what throttle linkage do you have?
Wed Jun 18, 2014 3:37 am
Howell tbi stock linkage. The truck is just not smooth. It's hard to explain
Wed Jun 18, 2014 11:52 am
I remember going from an old carb'ed rig to EFI and the throttle was hard to control. It was either idling or full throttle, nothing in between. I fixed it a little different way, but Viper has a great way of doing it. However, TBI is another animal, so I'm not sure if it'd help ya.
Wed Jun 18, 2014 2:23 pm
Seems like the spring iis really strong on the tbi
Thu Jun 19, 2014 7:36 pm
32,398,237 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
