It is currently Tue Oct 01, 2024 1:16 am
C4 install woes
I'm still in the process of trying to convert the yellow 72 (Terrible One) over to automatic and things are not going right.
Here's a list of parts I am working with. 1974 Bronco C4 1976 164 tooth, 28oz imbalance flex plate (from 76FordBronco) 1976 automatic starter 1974 Bronco engine plate/starter plate
After bolting everything up to the back of the block and flex plate, the crank is nearly impossible to turn over. I am lead to believe this is a possible indication that the either torque converter or input shaft have become unseated. When the bellhousing bolts are loosened 1-2 turns, or 1/8th-1/4 inch, the crank can then again be turned by hand with a breaker bar.
Second issue has to do with the starter. It simply will not bolt up. Now, I understand this is a moot point considering the first issue. However, the first problem should not have any bearing on the second, so as long as I am here, I'd like to know what's up. I can get only one bolt in, either top or bottom, but cannot bolt both up. When either bolt is snugged down even the slightest, this creates obvious pressure on the flex plate and prevents the engine from being turned over by hand. Additionally, I am seeing signs of wear on the gear housing of the starter from where the teeth on the flexplate are rubbing against it.
Any thoughts of ideas for how to remedy one of both of these issues?
Wed Jul 02, 2014 3:33 pm |
Re: C4 install woes
How about some pics of the parts. Sounds like converter may not be all the way in. When it is the flats on the converter studs will be about 1 inch into the bell.
Wed Jul 02, 2014 4:31 pm |
Moab Mike
Re: C4 install woes
Wed Jul 02, 2014 5:02 pm |
Re: C4 install woes
Pics would be kind of boring at this point as everything is still kinda sorta in the truck. But, if there is anything in particular you'd like to see, lemme know.
I plan to pick up a transmission jack tomorrow, pull the whole damn contraption back out, shove that converter in as far as possible, and then give it another go. I'll be sure to give the teeth on the pump a good looking over to see if any have been damaged during the first attempt at bolting up. For now, I am done for the day as my extra set of hands has left the house.
I couldn't tell you how far the flats were in before but there was very little left-right wiggle in the converter.
Wed Jul 02, 2014 5:04 pm |
Re: C4 install woes
And thanks guys. I'd really hoped to have had this done before surgery so I could be driving it by now. I guess in my haste I might have knocked the converter loose a bit while trying to bolt everything up before.
Wed Jul 02, 2014 5:05 pm |
RJLougee
Re: C4 install woes
Def sounds as if the TC is not seated all the way. Not to doubt, but make sure you're rotating it as you push it in so it's gonna allow the teeth to seat and fall into the pump gear. Hopefully it's not messed up from the current install.
If you need a hand I'm busy as H#$% till t he 17th, but then have a couple weeks off. Joe
Wed Jul 02, 2014 8:51 pm |
Re: C4 install woes
If the pump teeth are crap I'll just consider it the cost of failing to check twice.
I'm back to work on the 14th. If I haven't wrapped this up by the 9th I'll probably just push it off to the side until I'm healed up.
Wed Jul 02, 2014 8:59 pm |
Re: C4 install woes
I forgot I did actually take a few pictures today.
Wed Jul 02, 2014 9:45 pm |
Re: C4 install woes
Wed Jul 02, 2014 10:24 pm |
DLB
Joined: Mon Feb 21, 2011 10:56 am Posts: 48 Location: Fowler, CO
Re: C4 install woes
Did you remove the pilot bearing in the back of the crank? I have made this before.
Thu Jul 03, 2014 2:51 am |
Re: C4 install woes
Thu Jul 03, 2014 6:25 am |
Re: C4 install woes
Thu Jul 03, 2014 8:49 am |
Re: C4 install woes
Thu Jul 03, 2014 4:29 pm |
Re: C4 install woes
Which is easier to find? Pump gear or entire pump?
Thu Jul 03, 2014 4:33 pm |
Re: C4 install woes
Crap!
Thu Jul 03, 2014 5:38 pm |
Re: C4 install woes
Converter is seated now. I don't know if the previously shown damage is enough to completely sideline the truck. But I'm willing to see if it will fire up and move after reassembly. I'm versed enough in install and removal that later this year I will pull everything apart and replace those parts I think might be damage.
Thu Jul 03, 2014 8:10 pm |
Re: C4 install woes
Thu Jul 03, 2014 9:49 pm |
Re: C4 install woes
Word. Danke.
Thu Jul 03, 2014 9:51 pm |
Re: C4 install woes
So, to sum up how we (75DBE Jr and I) went about getting it seated...
After talking with Kirk on the phone and bouncing ideas off one another, we followed some Kirk advice. We pulled the TC and used a permanent wax type marker to coat the splines of the outer shaft and input shaft. The idea to confirm that the pump was simply not inserting fully. After the first test fit, we confirmed ~ 1/2" of splines not engaging on the input shaft. We then removed the TC again, inserted the input shaft into it fully, just to make sure it would completely insert. It did. Finally, we removed the input shaft from the TC and set it to the side, installed the TC onto the outer splines on the transmission shaft and fully seated it into the pump. After confirming it was indeed possible, it was simply a matter of trying one more time and this time shoving on the torque converter like we meant it. Problem solved.
Thu Jul 03, 2014 9:59 pm |
Re: C4 install woes
Or you could go by feel. Converter catches splines of stator, then input shaft engages converter, then hub seats in pump gear. In the end the flat should be 1" into the bell.
Thu Jul 03, 2014 10:12 pm |
Re: C4 install woes
Fri Jul 04, 2014 9:05 pm |
Re: C4 install woes
Fri Jul 04, 2014 9:32 pm |
Re: C4 install woes
Sat Jul 05, 2014 12:29 am |
Re: C4 install woes
Sat Jul 05, 2014 1:10 am |
Re: C4 install woes
I'll confirm today with my Grandpa but I believe it was sil-terhar ford.
Sat Jul 05, 2014 6:44 am |
Re: C4 install woes
Yes I did confirm today. Trans was rebuilt by sil-terhar ford with a lifetime warranty. After 6 years or so it began to crap out again so my grandpa took it back in. They were not happy to see it in there and try to deny the warranty. So they "Fixed" it under warranty. And thats where it's at. How the damage happened we are unsure. We installed the 351 and when that happened my uncle did the same as Zach. Didnt seat the converter all the way. Pulled the motor to reseat the converter. Got about 4k miles on it when it started to have shifting issues. Would "hang on a shift and flair". Pulled the valve body to find the valves were "sticky". So repolished them and off we go. All worked well for about 100 miles. We were up campin/wheelin. We stopped to collect fire wood. When we jumped back in the bronco thats when the trans crapped out. It still moved but made a bad grinding noise. We drove it like that about a mile back to camp and towed it home. Pulled it and replaced it. Thats where we are at now.
Sat Jul 05, 2014 4:33 pm |
Re: C4 install woes
I don't see anything that was put together wrong. Looks like the bearing might have come apart and took out the gears.
Sat Jul 05, 2014 7:23 pm |
Re: C4 install woes
Anyone know of a local place where I can buy a transmission shift lever bushing? This would be the rubber/plastic bushing that slides into the shift lever on the lower portion of the column and the shift rod to the transmission fits into it.
Wed Jul 09, 2014 11:48 am |
Moab Mike
Re: C4 install woes
One of the EB vendors carries them if you can wait a few days or I have a shift link with one on it.
Wed Jul 09, 2014 1:41 pm |
Re: C4 install woes
Order two from WH last night. Was hoping for a test drive today.
Afraid once they come out of the shift link on the column they are near impossible to reuse.
Wed Jul 09, 2014 2:20 pm |
