It is currently Tue Oct 01, 2024 7:25 am
[ 10 posts ] |
B.O.B.
Charcoal canister setup
So I think my fuel pump is dead, don't know for sure but that seems the case. I always seem to have a lot pressure built up after driving it. I can always hear it hissing when I stop. What is a good set up for a charcoal canister? What kind should I use? How would I plumb one in to my setup? I do have a aftermarket fuel tank but I don't have any extra vent lines coming out of it. Can I rig something that goes to the filler neck or should I drill another hole in the tank? Is all this pressure over working my pump possibly causing it to fail?
Any input would be appreciated.
Sat Jul 12, 2014 3:49 am |
Re: Charcoal canister setup
Howdy Bob,
I would say you found your problem.
If your tank isn't vented somehow it over works the pump.
I don't recall your set up but a lot of guys plumb a vent line into the fuel return line.
I think the 77 style vent system is the best / easiest. It is simply a vent line from the tank, an inline roll-over check valve, and the rectangular style canister mounted to the firewall.
Sat Jul 12, 2014 6:28 am |
Moab Mike
Before you pull the pump I would try running it with an alternate 12V power source.
What is your fuel pressure when your vehicle is running? Do you have any obstacles the fuel pump has to overcome in your fuel system?
Sat Jul 12, 2014 7:54 am |
My tank didn't have any extra barbs. I added a barb to the filler neck. Drilled & tapped for a npt x barb brass connector, then added a little solder. Worked great. I just used a tank vent/check valve, no charcoal cannister, but I don't have emissions or park indoors, so smell isn't a problem. You can smell the gas sometimes on hot days. Especially when you first start it up.
Sat Jul 12, 2014 8:15 am |
B.O.B.
On a charcoal set up, you have a line com the tank to the canister. Now do you need a line to the intake and then another to the return line in case fuel gets in.
What's a good donor vehicle for a charcoal canister?
Tue Jul 15, 2014 7:57 pm |
Any early 90's bronco, f150, ranger, some cars. If you standing at the open hood the canister is low left front near the inner fender battery and engine. At least on bronco and f150's. They are usually black have two mushroom cap breathers and two nipples.
Tue Jul 15, 2014 10:27 pm |
That's what Iam using on both my broncos
Tue Jul 15, 2014 10:28 pm |
B.O.B.
Still doing some research and found this diagram on cb.com http://classicbroncos.com/forums/showth ... t=charcoalMy question is: Where would I hook my vacuum line to the throttlebody?
Sat Jul 19, 2014 1:38 pm |
B.O.B.
Do you have to vent the charcoal canister to the manifold or can you just run a vent line to the canister and nothing else?
Tue Jul 22, 2014 8:57 pm |
Re:
Tue Jul 22, 2014 9:19 pm |
[ 10 posts ] |
