Ok I hope no one is offended by this!
My work truck has a re-man 3.9 cummins and is just getting (54,000)broken in. I'm going to replace the work truck in a few months and was thinking of using this motor. It has an intercooler and turbo. From what i have read its "fairly simple". Never know an engine swap to be simple! The main reason for the swap would be to ditch the carb crap!
Was hoping that someone out there knew something about this swap?
Even though I think the sexiest thing under the hood of a bronco is a 5.0!! Without a second thought!!! I have 3.9 thats a good running motor in hand, and only needs three wires to run. As oppsed to rebuilding a 5.0 and wiring it in place.
I know that the frame must be notched and new mounts made. And the oil pan has to be modified.(I have no fabrication skills!) I was more concerned about the wieght (750#) Almost twice the 302. And then the bellhousing and trans, I have heard some 351 bellhousings work. Power streering? i guess new lines maybe more?
The plus side of it would Great torque(700)#! And thats useable. just might find where the other weak points are, better carry extra u joints.
The 3.9 gets great mpgs. I have heard stories of a few crusing Denver, and even a whisper of one taking on a 351?
