www.ColoradoClassicBroncos.com - View topic - rear diff question
It is currently Fri Nov 22, 2024 6:15 am
Reply to topic  [ 8 posts ]
 rear diff question
Post rear diff question
I swaped my ARB into a new housing and got it all put back together. Why is it that when I rotate the axles the drive shaft does not rotate? What am I missing??
Fri Sep 12, 2014 8:00 pm
Post Re: rear diff question
Wait, what? So up on jack stands, xfer case in neutral, ARB engaged and rotating tires & the driveshaft isn't turning?
Fri Sep 12, 2014 8:19 pm
Also, is this with the ARB engaged?
Fri Sep 12, 2014 8:22 pm
ARB not engaged, t case in gear, trans in park and the axles rotate (yes up on jack stands) wtf?
Fri Sep 12, 2014 8:29 pm
they are supposed to. if you rotate the passenger forward the driver will travel in reverse. Lock the arb and try it again.
Fri Sep 12, 2014 8:51 pm
or lower one tire on the ground and try again.
x2. Works exactly like an open diff when open.
Fri Sep 12, 2014 9:22 pm
Thanks Rob, I was thinking to much about it to see the obvious.
Fri Sep 12, 2014 10:04 pm
32,944,055 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
