Register •
FAQ
• Login
It is currently Thu Oct 03, 2024 12:26 am
[ 5 posts ] |
TOOLMAN
Exploder fan
Okay fellas,
Quick question(s): how do you get the clutch fan off the water pump on the Explorer 5.0? Is it pressed on there? Maybe I wasn't doing something correctly? Also, which fan is preferable: the plastic or metal ones? It seems like the metal is on '97 and earlier while the plastic is on the '98 and later.
Thoughts?
Mon Sep 29, 2014 8:52 am |
Moab Mike
Re: Exploder fan
Two ways:
Buy a Ford clutch fan tool
Remove enough of the bolts to access the nut with a pair of Channel locks.
The later is more cost effective.
Mon Sep 29, 2014 9:07 am |
Re: Exploder fan
I have the removal tool if you would like to borrow it.
Mon Sep 29, 2014 11:03 am |
Re: Exploder fan
I also have the clutch fan wrench if you need it.
The metal one supposedly is slightly better - I don't know why exactly but must be because I have one. :)
Mon Sep 29, 2014 10:38 pm |
TOOLMAN
Re: Exploder fan
Thanks for the advice!
Jeff - I borrowed Chris' since he's a bit closer to me. Thanks for the offer!
Chris - Thanks for hooking me up with the tool.
Thu Oct 02, 2014 11:13 am |
[ 5 posts ] |
