Register •
FAQ
• Login
It is currently Sat Nov 23, 2024 2:04 pm
[ 3 posts ] |
Aluminum heads recommendations
trei75bronco
I have a mildly built 302 out of a maverick. I'm looking for more hp. Anyone have a recommendation. Anyone have any they're not using. Do I need a different head gasket I have 1.6 roller rockers on my heads now. Can I use them there stud mount. Need more all around power
Wed Oct 08, 2014 2:35 pm |
B.O.B.
Re: Aluminum heads recommendations
I know a lot of people use afr heads. Head gaskets should be regular unless you need a little extra clearance com the valves and pistons. If you want to use the same rockers then just make sure your new heads are compatible.
Wed Oct 08, 2014 9:28 pm |
Broncoguy73
Joined: Mon Feb 20, 2012 10:09 pm Posts: 126 Location: Highlands Ranch
I had edelbrock performer RPM cam, intake and heads. They are all dyno matched for each other. I had 1.6 roller rock on mine and it worked great.
Wed Oct 08, 2014 9:36 pm |
[ 3 posts ] |
