Register •
FAQ
• Login
It is currently Thu Oct 03, 2024 1:33 pm
[ 4 posts ] |
TRO Ruff Stuff set up question - Drag link before or after?
Friday
VENDOR
Joined: Sun Nov 14, 2010 9:24 pm Posts: 160 Location: Palmer Lake, CO
OK I made the tie rod up so my wheels are at least headed in the same direction. I've centered the axel under the frame and installed my track bar. Next on the list is the drag link. Should I wait to have the engine and body back on the frame before I do this. Will the added weight change the geometry? Now that I think of it, I might need to redial in my track bar too. Let me know what you all think
Thu Oct 09, 2014 2:56 pm |
DanHall
Joined: Fri Jan 17, 2014 2:38 pm Posts: 151 Location: Pueblo, CO
Re: TRO Ruff Stuff set up question - Drag link before or aft
Thu Oct 09, 2014 4:30 pm |
Keep in mind that you want the axle to strike the bump stops squarely, so you should be most concerned about where the axle is, left-to-right, at full compression. If the track bar's path causes it to sit slightly left at ride height, no problem. It is not uncommon for a properly engineered suspension to sit that way.
Thu Oct 09, 2014 10:00 pm |
Friday
VENDOR
So, I will wait to do the drag link till the weight is back on the vehicle. Track bar is the adjustable type so that's no big deal. Thanks for the input.
Fri Oct 10, 2014 10:30 am |
[ 4 posts ] |
