Register •
FAQ
• Login
It is currently Thu Oct 03, 2024 7:27 pm
[ 4 posts ] |
shop to resurface flywheel and check balance?
bsaunder
Joined: Sun Mar 16, 2014 8:20 am Posts: 27 Location: ~Denver, CO
What is a decent shop to use in Denver to resurface a flywheel and check the balance of it? If they can check the balance of the harmonic balancer as well, that would be even better.
_________________ -Ben '74 Bronco / Garage art - in stages of rising again ..figured out how to change my dork picture!
Mon Oct 13, 2014 11:54 am |
Re: shop to resurface flywheel and check balance?
I just recently had mine done by Scott at MPG Head Service in Englewood. He has worked on a lot of member's engines on here and I believe comes highly recommended.
Good Luck.
Mon Oct 13, 2014 8:04 pm |
x2 on MPG
Mon Oct 13, 2014 8:08 pm |
bsaunder
Thanks! I just talked to him and it sounds like he can do everything I need.
Wed Oct 15, 2014 3:53 pm |
[ 4 posts ] |
