It is currently Fri Oct 04, 2024 1:28 pm
[ 5 posts ] |
71Sport
exhaust removal
im changing out my dual exhaust to the 2 into 1 set up but am having a hard time getting to the lower nut on the passenger side any tips ?
Wed Oct 22, 2014 4:20 pm |
D&D72
Re: exhaust removal
the lower nut on the exhaust manifold?
Wed Oct 22, 2014 4:24 pm |
Re: exhaust removal
Swivels and extensions.
Wed Oct 22, 2014 5:49 pm |
Re: exhaust removal
That ^
And penetrant & heat alternating, then hit it with a impact. Make sure you have a good fitting socket.
Wed Oct 22, 2014 6:13 pm |
exhaust removal
X2. Use only 6 point sockets in stubborn bolts and nuts. 12 point will round it faster than you can scream an obscenity at it.
For the passenger side I think I used a 1/2" drive 6 point 5/8 socket with a swivel directly attached and a 12" extension on that. You'll likely take the stud with you, if it doesn't snap off. Don't sweat it and just let it come out.
Wed Oct 22, 2014 6:52 pm |
[ 5 posts ] |
