It is currently Fri Oct 04, 2024 7:26 pm
[ 9 posts ] |
Firing up sefi engine that's sat for a few years
bsaunder
Joined: Sun Mar 16, 2014 8:20 am Posts: 27 Location: ~Denver, CO
I'm slowly resurrecting my Bronco from a six year sleep - next item is preparing my engine to fire. I've already pulled the plugs and put some marvel mystery oil in the cylinders. I'm planning on draining the oil and then refilling with new, putting at least a quart in through the pcv breather to try and get most of the upper. I'll pull the dizzy and work the oil pump with a drill, re-stab dizzy, hand crank, and prime again. Also planning on making sure all the fuel lines are drained and then run the fuel pumps for a while (fuel pumps only, no crank) and change fuel filters. Water is in good shape as well are hoses, serpentine belt, etc. The engine (351w, sefi from 93 Mustang, roller cam and rockers..) is still practically new and barely broken in yet.
Anything else to check before I try and fire it?
_________________ -Ben '74 Bronco / Garage art - in stages of rising again ..figured out how to change my dork picture!
Tue Nov 04, 2014 4:43 pm |
Re: Firing up sefi engine that's sat for a few years
Condition of battery?
Tue Nov 04, 2014 5:14 pm |
bsaunder
Dead, dead, dead, not even 2 volts across the terminals so I'm not sure I want to try and charge. It's a procomp knock off of an optima.
getting a new one is on the list
Tue Nov 04, 2014 5:19 pm |
If it hasn't cranked over in six years I think I'd turn it over by hand a couple of times.
Tue Nov 04, 2014 6:15 pm |
Wed Nov 05, 2014 4:17 pm |
Swipe out the cylinders for cobwebs?? LOL! Seems like you have your bases covered to me. Lubrication is the key. If you have that covered it's unlikely you'll damage the engine.
Thu Nov 06, 2014 1:54 am |
bsaunder
Thu Nov 06, 2014 9:18 am |
I bet you'll be fine with a little oil in the spark plug holes and doing just what you said.
BTW im glad to hear you are getting it back up n running.
Thu Nov 06, 2014 7:00 pm |
I cant believe nobody has requested a video of it on the first test fire!
Fri Nov 07, 2014 5:44 pm |
[ 9 posts ] |
