www.ColoradoClassicBroncos.com - View topic - Ram assist mounting
It is currently Mon Nov 25, 2024 8:29 pm
Reply to topic  [ 3 posts ]
 Ram assist mounting
Post Ram assist mounting
I'm working on the mounts for my hydro assist ram and am wondering if there is anything I should be considering as I design it. Does it need to be parallel, or can there be a little angle without putting too much load on the tie rod ends? I know that mounting the tie rod to the top of the drag link can cause some slop in the steering-is this a concern with the ram mount as well? I'm also not sure how much load I should plan for. Any tips?
Thu Nov 06, 2014 10:28 pm
Post Re: Ram assist mounting
When you find out you can come set mine up :Welding:
Mon Nov 10, 2014 2:16 am
The more parallel the ram is to the tie-rod, the better, but there can be some angle in there. I'd try to keep it less than say 5deg.
I'm not a big fan of mounting one end to the diff cover as that has a tendency to loosen the cover bolts, then you have a leaking diff. You want to keep the ram away from the rocks, so the 1-3 o'clock position might work best. Also keep in mind what a deep snow bank might do to the hoses when considering position.
As for hoses, when I built mine, I went to the local Hydraulic shop and got some re-buildable connections and bought an extra three ft of hose in case I needed a repair in the field. That would not be fun without a vise, but I did it all the first time without one.
I believe these to be the fittings:
http://www.wideopendesign.com/Product/3 ... -Ends.aspx
Exploded view:
Mon Nov 10, 2014 4:56 am
Users browsing this forum: No registered users and 63 guests
33,094,075 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
