www.ColoradoClassicBroncos.com - View topic - C4 install question
It is currently Tue Nov 26, 2024 4:48 am
Reply to topic  [ 8 posts ]
 C4 install question
Post C4 install question
C4 install question
I have been leaking fluid from my dana 20 since I installed my c4 and the rebuilt viperwolf dana 20. I noticed there is fluid coming out the vent. Did I miss a seal and or a step in my install. I think I have transmission fluid in the tc cuz the royal purple is more red now. I've al been a np435 guy so this is my 1st auto install
Mon Nov 10, 2014 11:46 am
Post Re: C4 install question
Just to confirm, the vent for the t case? I'm no C4 expert but if you have trans fluid filling up the void b/t the trans and the t case and then building up in the t case I'd say the seal is missing or failed. Is your ATF low?
Mon Nov 10, 2014 4:50 pm
No missing seal. It will only come out the vent if it's over - filled or too hot.
Mon Nov 10, 2014 5:20 pm
It's com out the transfer case. I've been Wondering why fluid seems to disappear from my c4
Mon Nov 10, 2014 8:17 pm
There is a o ring on the bearing retainer big aluminum pc that was chewed up a little. Thought it would be fine.
Mon Nov 10, 2014 8:23 pm
I too am having the same issue. The first time was pretty bad and we replaced the seal. This time which is a couple of months later the same thing is happening but not nearly as bad as the first time. It's leaking again from the valve on top of the T-case. I have to periodically put more ATF in the transmission. I was also hoping if someone had any ideas as well.
Tue Nov 11, 2014 5:23 pm
Atlas
Tue Nov 11, 2014 11:07 pm
77 there are 2 places they can leak together. Both require pulling the t case to change. And if you do one better do the other also.
oring
seal
Wed Nov 12, 2014 6:46 pm
Users browsing this forum: Google [Bot] and 39 guests
33,125,872 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
