Register •
FAQ
• Login
It is currently Fri Oct 04, 2024 7:18 am
[ 2 posts ] |
in-lbs or end play?
I've read 2 different things for the j-shift front output. One says endplay between .003-.005. Other places say preload of 2-5in-lbs. So which is it? I know the rear output is endplay of .003-.005 Im about done with it and want to make sure I get it all set-up correctly. Also what size are the yoke nuts? I have a good source Im gonna try to see if I can get em.
Tue Nov 11, 2014 8:25 pm |
Re: in-lbs or end play?
Isn't it both, torque to spec & confirm end play? If end play is wrong then shim to the correct spec.
Tue Nov 11, 2014 10:12 pm |
[ 2 posts ] |
