www.ColoradoClassicBroncos.com - View topic - stock exhaust
It is currently Sun Nov 24, 2024 6:57 am
Reply to topic  [ 8 posts ]
 stock exhaust
Post stock exhaust
does anyone have a pic of the stock exhaust (single exhaust ) installed for 71 302
Thu Nov 13, 2014 7:22 pm
Post Re: stock exhaust
Not sure how much they changed but I have the original setup on my 75. What parts do you want pics of?
Thu Nov 13, 2014 9:32 pm
Mainly how the driver side cross over to the passenger side. I bought the set up from Bronco graveyard and it goes under the the front drive shaft. Seems like it's going to hit with articulation
Thu Nov 13, 2014 10:23 pm
OK, I'll grab a pic for you. Mine is similar. I have 2.5 inches of lift and haven't hit it that I know of with the drive shaft.
Thu Nov 13, 2014 10:59 pm
Sorry it took a bit. Here are some images of my exhaust. Please excuse the greasy mess of a transmission. My rear main is shot. :-)
First one is from the drivers side just behind the front tire.
Passenger side :
Hope this helps.
Adam
Sat Nov 15, 2014 2:53 pm
I don't know if it would help but I can take pics of TFB's stock setup, factory '76 exhaust.
Sat Nov 15, 2014 4:01 pm
that looks just like mine minus the cat, it just seems like that front drive shaft wont have much travel . I also have a 2.5 lift i didn't even consider that when i made the purchase , but it installed nicely . Thanks for the pics
Sat Nov 15, 2014 9:37 pm
As with any fixed end swing plane, the end of the driveshaft at the t case side does not move much. You're looking at, probably, 3 inches of total vertical movement at the point it appears the exhaust crosses it. I'm sure you're fine.
Sun Nov 16, 2014 8:38 am
32,992,641 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
