www.ColoradoClassicBroncos.com - View topic - 1978 Bronco Front Disc Brake Swap
It is currently Tue Nov 26, 2024 6:32 am
Reply to topic  [ 5 posts ]
Images: 14
Post 1978 Bronco Front Disc Brake Swap
I have a Dana 44 out of a '78 Bronco.
I was reading about doing an entire front end disc swap, from the knuckles out. Just doing the brakes, not swapping to full width on the Luber!
My question is... Can I really do this swap with my Dana 30? Or do I need a Dana 44 to begin with?
This is what I saw...
http://classicbroncos.com/disc-f150.shtml
¡Gracias!
Mike
Fri Nov 14, 2014 12:33 am
Post Re: 1978 Bronco Front Disc Brake Swap
You need a 44 to do the Ford brake swap. D30 uses kingpins instead of ball joints. You can do the chevy brake swap on a D30. http://classicbroncos.com/tech/chevy-di ... conversion
Fri Nov 14, 2014 12:53 am
Images: 14
Thanks Viper...
I was afraid of that :(
Fri Nov 14, 2014 8:56 am
I'm documenting my journey with the F150 swap. I have the used parts for the Chevy swap if you want to go that way. Spindles and caliper mounts. I have a thread going on my swap.
Fri Nov 14, 2014 12:10 pm
Do the Chevy swap it's cheap the brakes work good.
Fri Nov 14, 2014 3:16 pm
Users browsing this forum: No registered users and 25 guests
33,130,303 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
