www.ColoradoClassicBroncos.com - View topic - uh ohhh!
It is currently Sat Nov 23, 2024 1:15 pm
Reply to topic  [ 9 posts ]
 uh ohhh!
Post uh ohhh!
so the last time I drove my bronco was a few weeks ago and it started backfiring through the tb. Seconds before that I heard what I thought was a nut coming loose. Finally got to pop a valve cover off and found that #3 exhaust rocker stud broke in half. How does that happen? Now I need to find a new stud to replace this with. Does anyone know if the parts houses (autozone, oreillys) carries them.
Fri Nov 21, 2014 3:27 pm
Post uh ohhh!
Unless the stud was somehow fatigued, the most likely cause I can think of is a valve tapping a piston. How does the corresponding push rod look?
I don't think you're going to find a rocker stud at a big box parts house. I would try one of the online speed shops or maybe amazon.
Fri Nov 21, 2014 4:22 pm
Post Re: uh ohhh!
You probably need to check your timing chain to see if slack or a break lead to a possible valve/piston collision.
Fri Nov 21, 2014 4:25 pm
Post Re: uh ohhh!
Above and I bet a machine shop may have a few laying around.
Fri Nov 21, 2014 5:45 pm
Post Re: uh ohhh!
pretty sure NAPA and CARQUEST carry that stuff. (at least they have in the past)
Fri Nov 21, 2014 6:07 pm
Post Re: uh ohhh!
Push rod is fine . Still straight. I'll have to figure out a way to get me a new one.
Sun Nov 23, 2014 5:34 am
Post Re: uh ohhh!
So I have my 302 engine building book packed away and can't remember the way to correctly it ten the rockers. Any help would be appreciated.
Sat Nov 29, 2014 8:36 am
Post Re: uh ohhh!
I believe it was a bad stud as well. Working in the tire business I have seen many of wheel studs either fail due to cross threading or just fatigue/poor metal. You can definitely tell it was just a bad stud.
Sat Nov 29, 2014 8:38 am
Post Re: uh ohhh!
Finally got it all back together. Definitely needed to go back and adjust some of the other rockers. I'll run it a little bit more then maybe go back in for one more adjustment.
Fri Dec 05, 2014 3:52 pm
32,973,750 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
