It is currently Fri Nov 01, 2024 11:34 pm
[ 11 posts ] |
Help with BCB EFI Throttle Linkage
TOOLMAN
Initially I just hooked up the throttle cable and realized there was no way the cable was going to get me from idle all the way to WOT. So then, I decided to do Viperwolf's lovely progressive pulley setup and I still can't get the range from idle to WOT. Should I just be reserved to the fact that I can't get to WOT, or is there something I'm doing wrong? Bigger pulley perhaps (I used an 1-1/2")? I'm kind of stuck.
Keep in mind the TB isn't a finished product. I still need to get the helper return spring.
Tue Apr 28, 2015 7:39 am |
Re: Help with BCB EFI Throttle Linkage
Is the travel restricted or does it not have enough return spring pressure?
Tue Apr 28, 2015 8:12 am |
are you able to cut the cable a bit to get WOT and then adjust the pulley for full closed?
Tue Apr 28, 2015 8:22 am |
TOOLMAN
Tue Apr 28, 2015 8:47 am |
Bigger pulley and take the slack out of the cable. 20150424_163741.jpg IMG_3549.JPG IMG_3565.JPG
Tue Apr 28, 2015 10:21 am |
TOOLMAN
This is basically the pulley I bought.
I'll go try a bigger one tonight. Along with the return spring. That should get the slack out of the cable that's shown. The TB is slightly open in pic because that spring isn't there yet. Didn't know which spring to get when I was at the store last night. After measuring, it should be ~3.5".
I have the adjustment slot cut in the TB arm like you have.
Thanks guys for the input!
Tue Apr 28, 2015 11:21 am |
TOOLMAN
2" Pulley seemed to nearly do the trick. It gets to about 85-90% of WOT. I think this will at least get me going.
Wed Apr 29, 2015 9:48 am |
Did you cut any part of the cable? I had to cut at least an inch off mine.
Wed Apr 29, 2015 10:45 am |
TOOLMAN
Wed Apr 29, 2015 11:56 am |
Wed Apr 29, 2015 12:52 pm |
TOOLMAN
Wed Apr 29, 2015 1:11 pm |
[ 11 posts ] |
