www.ColoradoClassicBroncos.com - View topic - Dana 44 ring gear engraving
It is currently Sun Oct 06, 2024 11:21 am
Reply to topic  [ 5 posts ]
Post Dana 44 ring gear engraving
So, tonight I finally got around to opening a Dana 44 I picked up several months ago. The good news it is a 4.09 ratio with Trac-Loc.
While checking things out on the inside, I found an "A202" hand engraved into the outside of the ring gear. Anyone have any idea what that might mean? I'm thinking it was done by a PO. I'm just curious if it sounds like it would be pertinent to the set up or something.
Sat May 09, 2015 8:24 pm
Post Re: Dana 44 ring gear engraving
It was probably done during manufacturing to identify the pinion gear matched to it.
Sat May 09, 2015 9:09 pm
I'll buy that.
Sat May 09, 2015 9:28 pm
Yep usually you will find the same phase engraved on the pinion to signify the pair. Also I use to see a +2 or -1 hand engraved on the end of the pinion. This was to show the approximate pinion depth during setup, unfortunately it seems gear manufacturers have stopped doing this.
Sun May 10, 2015 9:14 am
Profile WWW
I have a feeling, based on the slop in this set up, that it's probably an OEM set up.
Sun May 10, 2015 9:52 am
32,474,432 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
