Gunnibronco wrote:Carter P4070 low pressure pump
Airtex E2000 high pressure pump (cross reference as late 80's truck/Bronco EFI pump)
LP pump has been in only 1 year. I swapped it due to Viperwolf's warning about the LP pump I was running. HP pump has been in 3 years.
76fordbronco wrote:I originally installed a frame mounted fuel pump on my EFI install but it wouldn't pull enough fuel pressure to run my engine. I then went to an internal tank fuel pump, it has been running flawlessly ever since. I'm not sure the difference but my experience is but the internal pump has performed better than I expected.
Viperwolf1 wrote:I like simplicity. I believe on Shawn Gregg's we just put an e2000 pump close to the tank (low as you can get it). I don't think he has had any problems with it. That's what I would try first. If you have problems then you can invest in a more complicated system.
D&D72 wrote:An in tank pump would be my preference if I had the tank for it. not ready to part with the $$ just yet.
Jesus_man wrote:Old thread sorry, but I know my Holley LP pressure is likely done. So is this Carter pump still the go to? It's half the price the Holley is, and only slightly larger.
