www.ColoradoClassicBroncos.com - View topic - Tell me the procedure for heater installation
It is currently Fri Nov 01, 2024 3:28 am
Reply to topic  [ 9 posts ]
Post Tell me the procedure for heater installation
Removed, rebuilt the heater box.
Royal pain to reinstall, mainly because the control cables...are short.
Give me the proper procedure and save me some time.
Mon Sep 21, 2015 9:18 pm
Post Re: Tell me the procedure for heater installation
I never found one. Swearing helps.
Actually, you could probably put the cables on, then tighten down the screws on the box. Probably give you a little wiggle room.
Mon Sep 21, 2015 9:48 pm
Did you pull the glove box out? It gives you better access and is easy to remove.
Tue Sep 22, 2015 7:03 am
Just what Justin and Kinder said. Lots of cussing and getting mad.
BTW did you do the blower motor/cage upgrade? It's a must do!
Tue Sep 22, 2015 1:07 pm
I've pulled mine in and out a few times and it is possible to loop the control lines on before you bolt it to the firewall. I usually put the heater outlets through the firewall lean the box down then reach behind the box like a contortionist and put the ends on. I know there is at least one holder that you screw in and you can get to it but it's a blind loosen/tighten. If that makes sense.
Wed Sep 23, 2015 7:14 am
throw door inserts & doors bars into help the excitment for any underdash needs, the profanity is bound to flow!!! Sure they both are functional and look great but, gaul durn!!!
Wed Sep 23, 2015 1:30 pm
Thanks for all the help. The heater is installed. Cost $74 down at my mechanics shop. I'm at a point in life where time is money and I didn't have the time to mess with it.
Erik
Fri Oct 30, 2015 9:24 am
Images: 14
Fri Oct 30, 2015 10:44 am
Sat Oct 31, 2015 4:01 pm
32,738,998 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
