www.ColoradoClassicBroncos.com - View topic - Power steering belt squeal
It is currently Fri Nov 01, 2024 11:31 am
Reply to topic  [ 6 posts ]
Post Power steering belt squeal
My power steering belt keeps squeaking and just can't seem to get it taight. Seems like the bracket is bending and causing it to loosen up. I have the one bolt going into the head and the adjuster bracket into the water pump. Is there any other bracket or anything that might work better or be more sturdy without doing the serp setup?
Sun Oct 18, 2015 6:23 pm
Post Re: Power steering belt squeal
I used a slightly modified bracket off an old Ford van with a piece of pipe for a spacer and could get it tight enough to not squeal. There was no flex in the bracket. Make sure you have the right size pulley though. The one I grabbed at the yard was made for a wider belt and never worked. Ended up getting a new pulley at Napa that worked well.
Sun Oct 18, 2015 8:59 pm
The bracket is sitting in a bin in the garage and wont be going back on with the "new" engine. If it is worth a trip to Pueblo to you, you can have it. I was running a dual return saginaw pump.
Sun Oct 18, 2015 9:34 pm
I might hit you up on that. My dad lives in P west so maybe I could head down there soon. I used to live off 28th lane.
Mon Oct 19, 2015 6:41 am
I'm also happy to pick up on my next trip down there. Might be a few weeks, though.
Mon Oct 19, 2015 1:13 pm
I'm out in the county too, just North of County High.
Mon Oct 19, 2015 4:42 pm
32,744,624 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
