www.ColoradoClassicBroncos.com - View topic - Heater upgrade
It is currently Thu Oct 31, 2024 7:29 pm
Reply to topic  [ 10 posts ]
 Heater upgrade
Post Heater upgrade
So now that I am driving the Bronk more I definitely need more heat during those cold days. Looking into doing the heater upgrade and was wondering if you need the cage and motor or if just the motor would work. Any thoughts on if there is a big deal comparing one from the other?
Mon Nov 23, 2015 10:23 pm
Post Re: Heater upgrade
Just buy a good blanket and keep it in the truck. Lol
The motor and the cage are said to be the good recipe. The motor is crazy faster than the stock Bronco unit. And the cage does the job of translating that to more air. You might be able to get away with the smaller cage on the better motor for some increase though.
Have you insulated your Bronco yet?
Mon Nov 23, 2015 10:55 pm
Yes motor and cage. I posted the part numbers I used about a year ago. easily available at napa and cheaper than buying it from a vender. You do have to cut the opening a little bigger but it's well worth it.
Tue Nov 24, 2015 6:42 am
Agreed. If you're gonna do it, the extra $15 is worth the bigger wheel.
Tue Nov 24, 2015 3:26 pm
And buy a new Amp for your stereo. The price of the bigger cage and motor is more noise in the cab.
Wed Nov 25, 2015 1:01 am
Doesn't need to be a Chev. blower motor.
One from a '92 or so F250 will work too.
Thu Nov 26, 2015 10:19 am
I found a 97 F350 with a 351w. Will that heater system work ?
Fri Nov 27, 2015 10:14 am
Sat Nov 28, 2015 3:02 am
Sat Nov 28, 2015 8:20 am
Sat Nov 28, 2015 2:16 pm
32,733,164 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
