www.ColoradoClassicBroncos.com - View topic - Disk/drum brakes with disk/disk master
It is currently Wed Nov 13, 2024 12:37 am
Reply to topic  [ 10 posts ]
Post Disk/drum brakes with disk/disk master
This is going to sound stupid.
I've been running a 99 Mustang GT hydroboost & master cylinder on disk/drums for YEARS. On both my stock width & full width axles.
I know this isn't exactly right. I think I've read I might be lacking rear brakes because there isn't a check valve or something that would keep the rear cylinders "pumped up" between uses. I think I even read it can cause the cylinder to retract & the rear brakes can fail completely.
Since I pulled my frame mounted rear brake line, and have drained the system of fluid, I'd like to fix this now. I hate bleeding brakes, and my hatred prevents me from modifying any part of the brake system, unless absolutely necessary. So now is the time.
Can someone tell me what I need to add to the system to get it right?
Sun Feb 21, 2016 10:32 am
Post Re: Disk/drum brakes with disk/disk master
You are talking about the residual pressure valve. Most new masters don't have them even for drum/drum setups.
I am right there with you on the hatred of bleeding brakes. I have everything to do the rear swap to Explorer discs but haven't for that very reason.
Sun Feb 21, 2016 11:08 am
Just realized you might be needing a proportion valve to adjust the bias as well. Not sure if you are locking up the rears before the fronts.
Sun Feb 21, 2016 11:18 am
Sun Feb 21, 2016 11:50 am
drums require a 10psi residual valve to keep the cylinders from collapsing. disc's use 2psi or less. You can pick them up pretty cheap. http://www.summitracing.com/parts/wil-2 ... /overview/
Be forewarned that with this you will need the adjustable proportioning valve.
Sun Feb 21, 2016 12:24 pm
Thanks Rob,
I'll leave the prop valve in.
Sun Feb 21, 2016 2:52 pm
This makes bleeding brakes easy.
TJ
F. Scott Fitzgerald
Tue Feb 23, 2016 1:45 am
I think I got one for $25.
TJ
F. Scott Fitzgerald
Tue Feb 23, 2016 1:46 am
I used one of those when I bled the 69 I flipped. It did go pretty well, still finished the job the 'old fashioned way' (with a helper).
Tue Feb 23, 2016 8:26 am
Mon May 16, 2016 11:36 pm
32,863,182 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
