www.ColoradoClassicBroncos.com - View topic - New Battery and smoking wires
It is currently Fri Nov 22, 2024 9:27 pm
Reply to topic  [ 10 posts ]
Post New Battery and smoking wires
Okay...newbie here! I installed a new Optima battery and these two connectors started smoking. Is it the wrong size battery and where do I start trouble shooting the electric.
Gracias!
BobbyImage
Sun Mar 13, 2016 11:50 am
Post Re: New Battery and smoking wires
Moved to '4x4 tech'.
Sun Mar 13, 2016 12:39 pm
You appear to have a wire missing from your starter solenoid. And it looks new. Did you recently replace that as well?
Sun Mar 13, 2016 1:26 pm
New solenoid and took wire off to look at connectors, but was connect before.
Sun Mar 13, 2016 2:21 pm
Ran after replacing solenoid and then battery died over winter.
Sun Mar 13, 2016 2:23 pm
Looks like it was spliced and then silicon caulked??
Sun Mar 13, 2016 2:30 pm
Build Thread:
Mon Mar 14, 2016 4:45 pm
Okay...fixing loose connections and found fusible link was cookedImage
Tue Mar 15, 2016 9:08 pm
Okay...after a bunch of soldered connections and a new solenoid I finally have fixed the problem. Thanks guys.
Sun Mar 27, 2016 9:43 pm
Thumbs up!
Mon Mar 28, 2016 8:57 am
Users browsing this forum: No registered users and 52 guests
32,958,363 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
