www.ColoradoClassicBroncos.com - View topic - LED Lighting with resistors
It is currently Fri Nov 22, 2024 12:22 pm
Reply to topic  [ 47 posts ]  Go to page 1, 2  Next
Images: 14
Post LED Lighting with resistors
I'm working on putting LED lights in for rear brake lights. They are just LED bulbs, not the big fancy LED computer board style.
In the diagram, it shows me how to hook up the resistors but my question is - do I put it on the truck side with the three wires or the light side with only two wires?
Here are some pics to go with my babbling...
PS - i'm not concerned with the back up light which is the 2 into 1.
Tue Mar 22, 2016 7:55 pm
Post Re: LED Lighting with resistors
Why don't you just get a couple electronic flashers and not worry about the resistors.
Tue Mar 22, 2016 8:54 pm
Build Thread:
Tue Mar 22, 2016 9:19 pm
Images: 14
What exactly do you suggest?
Meaning, what else do I need to buy and where do they go?
Tue Mar 22, 2016 9:21 pm
Images: 14
Maybe something like this?
Let me ask you this? Does it matter if all of my outside lights (minus headlights)blinkers parking lights brake lights are all LEDs but interior speedometer lights are stock with this flasher?
Sorry I don't know Jack about electricknicity!
Tue Mar 22, 2016 9:28 pm
Doesn't matter if you mix and match. The correct flasher has 2 prongs. They go near the steering column.
Tue Mar 22, 2016 10:50 pm
You can mix LED and regular bulbs. The resistors are used on the blinkers because the old bi-metal flasher units require a certain amount of electrical load to flash at the correct rate. LED are too efficient and cause the blinkers to flash quickly. The resistors are to add load. It's a bit of a waste.
Here is a 2-prong flasher that says it's rated for LEDs
Build Thread:
Tue Mar 22, 2016 11:18 pm
Images: 14
Terrific!
That looks simple enough. Thank you both for taking the time to reply and doing some legwork for me, I really appreciate you Both!
I saw a thread on CB.com and I almost ordered the wrong one, they were saying it was the one with three prongs and a ground!
Wed Mar 23, 2016 12:10 am
Images: 14
I think the light blue one is actually labeled flasher, and the silver one has paint on it so I can't tell what it says.
I only need to replace the one, with the electronic LED flasher though?
Wed Mar 23, 2016 12:28 am
Just following as I'd like to do something similar someday!
Wed Mar 23, 2016 2:56 am
Wed Mar 23, 2016 11:19 am
Definitely get an LED Flasher! my new truck doesn't have an actual flasher so I had to get resistors (Full LED's & HID driving & Headlights). On the older rigs there is no reason to fight with the resistors.
Just turn your signal on & grab the flasher, that's the easy way to tell which one is which in regards to flasher for turn signals or hazards. Here's a total kit : http://www.cjponyparts.com/led-light-ki ... 7/p/LEDK2/
'77 Sport, 302 HO on it's way to a resurrection!
'03 Mercedes CLK 320 Cabriolet (W208 body)
'13 Ford F350 Lariat Crew Cab 4wd Power Stroke
Wed Mar 23, 2016 4:09 pm
Images: 14
Wed Mar 23, 2016 6:34 pm
Images: 14
Wed Mar 23, 2016 6:39 pm
Images: 14
Ok, so I only bought 1 Flasher, so far. I replaced the flasher with the new LED flasher. The one in the picture is the one I bought… Thanks Digger!
All the lights work when you turn the light switch on.
Only the turn signals on the right/passenger side blink.
The driver side blinker is super super faint and only turns on at about 2% of its total power and doesn't blink it all. Just stays very, very faintly lit when it is supposed to be blinking.
Any thoughts or comments?
Wed Mar 30, 2016 1:29 pm
A hammer?
https://www.youtube.com/watch?v=6xsVX6029rU
Wed Mar 30, 2016 1:41 pm
Images: 14
Wed Mar 30, 2016 2:57 pm
Check grounds on the left.
Wed Mar 30, 2016 4:53 pm
Thu Mar 31, 2016 12:02 pm
Images: 14
Yes, all the outside lights, minus headlights are all LEDs now.
I did find that on both front blinkers, the ground wires were not attached!
I used a dremel to sand where the grounds attach to the bare body.
Then I went to the back and replaced the rear lighting wiring with some old, unchopped stock harness I had. I finally added New license plate light (stock bulb non LED) I had not put in since paint. All connections are tight, all grounds are grounded.
I switched the new flasher with the other and it still doesn't work right.
Only the Right brake light works when I push the brake. I just ordered another LED Flasher.
I'm just about 2 WTF's and a GDMF-er away from bagging the whole deal.
Thu Mar 31, 2016 9:58 pm
Flashers have nothing to do with brake lights. If the hazards or turn signals work on both sides the problem is in the turn signal switch.
Thu Mar 31, 2016 10:21 pm
Images: 14
With the new flasher in place and I get nothing or like I said before about 2% of a dim glow when I turn the left or right signal on.
When I switch both flashers, I flip the turn signal right or flip left and either side stays on, but doesn't flash.
Thu Mar 31, 2016 10:27 pm
Images: 14
Before I started... EVERYTHING WORKED. (with stock bulbs)
I have converted to LED's and replaced 1 stock flasher.
NO TURN SIGNALS- ONLY RIGHT BRAKE LIGHT.
No front left fender marker & no right rear quarter marker.
Sofa King frustrating!!!!!!!!!!!!!!!!!!!!!!!
Thu Mar 31, 2016 10:35 pm
Fri Apr 01, 2016 12:08 pm
Images: 14
Yes I did...viewtopic.php?f=5&t=8231
BUT... everything worked just fine after I installed the new cam into the "new to me" column.
All I changed was the light bulbs for LEDs + 1 Flasher.
Is it possible the flasher isn't really LED?
Fri Apr 01, 2016 12:19 pm
if the one side is flashing normal then the likelihood is the flasher is fine. So the $64 question is, do they flash normal when you run the hazard lights, or at least flash in unison with the same amount of light on each side?
Something is definitely going on with the continuity in the circuit. My next question is did you attach the ground wire on the flasher? The pic you showed has a ground wire. I sometimes get in a hurry and overlook such stuff is why I ask.
Fri Apr 01, 2016 12:28 pm
Images: 14
When I installed the new turn signal cam and wiring, I didn't hook up the 1 wire to the hazzards.(or the horn)
I bought the Black one, NOT the Blue one with the ground wire.(as per the suggestions listed above)
Fri Apr 01, 2016 12:55 pm
There may be a possibility the +/- are switched. I read a couple forums where they said they had to swap the input of the prongs from the flasher. A quick check might be to run a test light into the plug and switch the turn signal to the side that is working, then check which point is hot against their schematic to see if the load/battery iare on the proper side. Again I'm not sure how this effects the brake light because only the column switch controls the brake lights, not the flasher. Have you tried swapping the bulbs from one side to the next to see if it's a shorted bulb? I'd start with the back since that's the only side the brake feed goes. Also this flasher works with LED or standard incandescent bulbs, so maybe pop an old bulb in it and see what happens.
Fri Apr 01, 2016 2:25 pm
Images: 14
Thanks for the help! or at least trying, kind of hard over the computer.
This will be my plan of attack...
1) I'll double check that all the connections from the 8 prong column harness are secure and tight.
2) I'll swap rear Rt/Lt tail lights to make sure they are each working.
3) I'll try and swap the in/out on the flasher
4) I'll cuss like the SOB wants me too
5) I'll shoot out the eFFing tires!!!
6) I'll change it all back to the incandescent bulbs...
7) I'll go to the liquor store and forget about this till Monday!
8) Monday I'll list all my LED CRAP for FREE on Craigslist!
Fri Apr 01, 2016 2:47 pm
Fri Apr 01, 2016 2:57 pm
32,950,272 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
