www.ColoradoClassicBroncos.com - View topic - She's dead
It is currently Fri Nov 01, 2024 2:31 pm
Reply to topic  [ 12 posts ]
 She's dead
Images: 11
Post She's dead
Well guys,,, it's finally happened. I knew this day would come eventually.
I pulled into my neighborhood on the way home from work. There were a couple really load screeches and then a violent shutter,, then no power. Along with this came that wonderful smell of coolant. Coolant everywhere. (I was feeling really NASCAR at that point)
Originally I thought, okay, blown hose. No problem-o.
Opened the hood and everything is covered in oil and coolant. Yikes.
Looks like its all coming from the top area of the water pump.
Luckily a nice older gentlemen was driving by when I stopped and pulled me to my driveway. Whew that was lucky!
So any suggestion on where to start this process?? Water pump? Engine?
Rick
Wed May 18, 2016 6:23 pm
Post Re: She's dead
I am certainly not the best mechanic here but I would start with heads and head gaskets and see whats going on in there. You will be able to check a lot of other things along the way.
Wed May 18, 2016 8:27 pm
Images: 11
Post Re: She's dead
After getting her in the garage, I checked the oil. Clean, looks great. I gotta go out of town this weekend but will try and get into the water pump area first. Thats where I'm seeing the oil.
Wed May 18, 2016 8:44 pm
Post Re: She's dead
Hmmm, oil in the area of the water pump is usually coming from the front of the intake manifold.
Thu May 19, 2016 7:41 am
Images: 11
Post Re: She's dead
Thats kinda what im thinking too. Going to first remove belt to isolate if this is just a WP issue. See if she'll start and if still noisey. Then tear into it from the front. Should be interesting.Image
Thu May 19, 2016 8:06 am
Images: 11
Post Re: She's dead
Hard to get a good photo of the area. But oil has collected all around the top of the WP
Thu May 19, 2016 8:07 am
Post Re: She's dead
You indicated that it lost power after screeching and shuddering.........
leaky intake or blown water pump usually wouldn't cause that
what about the coolant loss, where was it coming from (don't really see any on top of water pump)
Does it turn over but not start ?
Maybe the distributor gear is taking some time off ?
Thu May 19, 2016 8:21 am
Images: 11
Post Re: She's dead
Couldn't really find a definitive source for the coolant leak, no busted hoses, etc. Not sure at all, but its definitely gone. Dip stick not showing any in the oil, so thats a plus at this point.
Thu May 19, 2016 8:24 am
Post Re: She's dead
Thu May 19, 2016 9:38 am
Images: 11
Post Re: She's dead
Thanks Zac. I'll try and get to it tonight.
Thu May 19, 2016 9:40 am
Images: 11
Post Re: She's dead
Early estimates are front bearing in WP. I'd guess 3/8" run out. Lol
Thu May 19, 2016 4:13 pm
Images: 11
Post Re: She's dead
So, I took Zach's advice and checked the oil. No watery goo was found. Whew thats good.
Next we checked compression. All 8 cylindars are between 90-100 psi. So that looks ok.
We installed a WH water pump, thermostat, and new housing with sensor port. Bolted it all up last night and finished this afternoon.
I think she's all good now. But I would like to change from the expansion tank radiator to a newer style in the future.
Cruzin at the rodeo tonight!
Rick
Sat Jun 04, 2016 7:52 pm
32,746,435 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
