Mustang h-boost & 4x4x2 gear fitting sizes, cooler placement
Postby Gunnibronco » Sun Jun 05, 2016 6:34 pm
I'll start searching, but I figured someone here might know.
I need the easiest way to make up lines from a Saginaw p/s pump, to a Mustang GT h-boost unit, & 4x4x2 box (also which port is pressure side & which is return side). Need fitting sizes & suggested methods, kits, etc. I don't know if I can have this stuff made here locally.
Also where does a p/s cooler fit in the mix? Diagram?
Thanks.
Re: Mustang h-boost & 4x4x2 gear fitting sizes, cooler place
Postby Gunnibronco » Sun Jun 05, 2016 7:02 pm
Follow up question, I've never worked with -an hose. Can Russell hose be used with Aeroquip fittings? Or are things proprietary?
Postby Viperwolf1 » Sun Jun 05, 2016 7:59 pm
Gunnibronco wrote:Follow up question, I've never worked with -an hose. Can Russell hose be used with Aeroquip fittings? Or are things proprietary?
Keep the hose and fittings from the same manufacturer, there are differences. I highly recommend Aeroquip Teflon -6 hose. It has a much higher pressure rating than regular -6 hose. You will need steel fittings for this hose. It is actually pretty easy to work with and it will last forever, even in a 1500 psi power steering system.
http://www.summitracing.com/parts/aer-fcc0620
http://www.summitracing.com/parts/aer-fbm1122/overview/
Postby Gunnibronco » Sun Jun 05, 2016 8:05 pm
Thanks for the info.
Best way to cut the stainless braided hose? Sharp metal chisel?
Here is a pretty good list of stuff needed for the Mustang and maybe the Super Duty h-boost. Specifically, the special adapters Hydratech (PN HBS9106) sells.
http://classicbroncos.com/forums/showpo ... ostcount=4
http://www.hydratechbraking.com/hose_fittings.html
Postby Viperwolf1 » Sun Jun 05, 2016 8:18 pm
Sharp chisel works and so does cutoff wheel.
Postby Eck » Sun Jun 05, 2016 8:25 pm
This video will explain pretty well how to make your hoses. It's actually pretty easy.
https://m.youtube.com/watch?v=PeeflgGlenY
Postby ZOSO » Mon Jun 06, 2016 4:50 am
For hose and fittings check out http://www.anfittingsdirect.com Im running their ptfe stainless lines and fittings in my can and have yet to have an issue. Also a lot cheaper price wise. Im getting ready to place my order for some -6 and fittings for my HB and fuel system.
Also a local Colorado company.
Postby Rox Crusher » Mon Jun 06, 2016 5:35 am
Eck wrote:This video will explain pretty well how to make your hoses. It's actually pretty easy.
that guy has a mobile vice just like mine
icon biggin
Postby Gunnibronco » Mon Jun 06, 2016 6:21 am
Thanks for all the great info!
Postby Viperwolf1 » Mon Jun 06, 2016 9:03 am
This is a better video for the Teflon hose. https://www.youtube.com/watch?v=3tjRsbSDA48
Postby Gunnibronco » Mon Jun 06, 2016 11:03 am
ZOSO wrote:For hose and fittings check out http://www.anfittingsdirect.com Im running their ptfe stainless lines and fittings in my can and have yet to have an issue. Also a lot cheaper price wise. Im getting ready to place my order for some -6 and fittings for my HB and fuel system.
I have them bookmarked, but forgot about them. I like the black hose, and they have a better selection of elbow fittings.
Viperwolf1 wrote:This is a better video for the Teflon hose. https://www.youtube.com/watch?v=3tjRsbSDA48
Thanks.
Postby Gunnibronco » Mon Jun 06, 2016 11:20 am
Any advice regarding the special vice insert that holds the fittings? Will hard plastic or wood work to do a few?
Postby landshark » Mon Jun 06, 2016 11:58 am
I used wood when I did mine
Postby Justin » Mon Jun 06, 2016 2:45 pm
x2. I used a chunk of 2x4. Worked great.
Postby ZOSO » Mon Jun 06, 2016 5:00 pm
if you go ptfe you dont need a vice to assemble them. They use a compression style fitting.
Postby Gunnibronco » Thu Jun 09, 2016 2:01 pm
So I have the 2 steering boxes disassembled. What should I do while its open? I have the seal kit.
4x4 sector shaft is good, no scoring.
Fluid from the 4x2 box was grungy.
