BroncoCrawler wrote:I believe Digger has the winning answer. I now remember that I cut the rockers off the same week I installed the 35's all those years ago. I will take some pics of my setup but it is basically exactly like the drawings but with a diagonal bar from the B pillar down to the top of wheel tub. I have not had the hard top on it in 15 years and last summer I took the hard doors off and put inserts and soft doors in.
It does it from 50-65 mph on any highway and is very repeatable. Doesn't do it on dirt roads probably because I'm not doing 50+ doesn't do it on the trail either.
BroncoCrawler wrote:I was running 30 but ive also noticed that when im done wheeling and I only air back up to 20 with the powertank the shake seems better but then again it can still get in rythym and get get bad even at 20psi. Do you have any pics how of how you tied your a-pillar bars to the firewall? I was also going to add a dash bar and probably some floor bars too. I'd like to mount the seats to cage eventually.
BroncoCrawler wrote:I'm always open to ideas. So do you have your rockers welded to the body or to supports and then your frame? I've been doing non stop reading about hard mounting the cage to the frame or use bushings. I'm leaning towards bushings since i still drive it on the street.
BroncoCrawler wrote:Those are perfect thank you! Will you be at the swap meet sat?
