by B.O.B. » Fri Jul 08, 2016 8:50 pm
So went wheeling this past weekend and ran into a few snags (and some trees as well). New issue is I cracked a fuel line and had to drop the tank. Used the in tank pump to drain some fuel after I fixed the tank so it was easier to put back in place. I did start it and moved the truck. Next day went out and no fuel pump. After some searching I did find my fuel pump fuse was blown. Replaced it but everytime I turn the key to prime the pump it blows the fuse. Any ideas?
