Dana 44
Dana 44
Postby cravenbronco » Mon Jul 25, 2016 4:19 pm
The ball joints are frozen in it. I have tried to use penetrating oil and nothing. I tried to heat it up and use a big hammer and still nothing not even a little movement. Any ideas of what else might work.
cravenbronco
Re: Dana 44
Postby horseplay » Mon Jul 25, 2016 4:45 pm
Hey Matt you need to pickup my ball joint press kit. It's like a big C clamp with press cups.
horseplay
Re: Dana 44
Postby Kinder » Tue Jul 26, 2016 7:54 am
If you want to drive I'll be happy to let you use my 20 ton shop press. But horseplay is on the right track, I'll add that if you cycle the heat with cooling and a good beating they should eventually loosen up.
Re: Dana 44
Postby Justin » Tue Jul 26, 2016 5:28 pm
Not sure where you're located, but I can offer up my press as well.
Re: Dana 44
Postby cravenbronco » Tue Jul 26, 2016 6:05 pm
Cool thanks everyone I'll see how far I get and keep you posted.
cravenbronco
Re: Dana 44
Postby cravenbronco » Tue Aug 30, 2016 8:12 am
Looking for a carrier and ring and pinion with 4.09 or 4.10 gear ratio. Open diff is fine. If anyone has any idea where to get one. I have got prices from 200.00 up to 700.00. I'm a broke white man and can't afford to go new. shrug
cravenbronco
Re: Dana 44
Postby Justin » Tue Aug 30, 2016 8:40 am
I might have one. Can't remeber the ratio I've got, but can look tonight.
Re: Dana 44
Postby cravenbronco » Tue Aug 30, 2016 11:50 am
That would be great
cravenbronco
Re: Dana 44
Postby cravenbronco » Wed Aug 31, 2016 6:17 pm
Got a lead on a D44 with 4.09 gears along with the whole housing today. He is asking $350. Sound fair?
Plan on going out to take a look at it and see what condition It is in tomorrow morning.
And if I do decide to pick it up I will have a extra housing with 3:54 gears.
cravenbronco
Re: Dana 44
Postby Justin » Thu Sep 01, 2016 7:57 pm
Looks like my gears are 3.5. That price isn't great, but isn't terrible either
Re: Dana 44
Postby cravenbronco » Fri Sep 02, 2016 2:23 pm
Here's the plan :
Going to get the carrier ,spider gears ,install kit ,axle seals ,ring and pinion.
my question is I have never set up a ring and pinion so where can I go to get it all put in and sealed ? Or who is recommended ?
cravenbronco
Re: Dana 44
Postby Justin » Fri Sep 02, 2016 6:57 pm
Crawler tech 4x4.
