Is it considered acceptable that I'm using rubber EFI fuel hose & clamps on an E2000 pump built for the Ford factory nylon snap lock hoses? I ran it for years that way, no problems, no leaks. But if there is a likelyhood the hose could pull off the pump, I'd probably change it out for one made for rubber hose. I just bumped into this one while reading up on Explorer EFI.
https://www.amazon.com/dp/B001BFOBXA/re ... 4f8fc2ef_S
I'm happy leaving it as is, if I'm not flirting with disaster. I haven't read anything about mixing line/fitting types. And I know the E2000 pump has been used a lot, probably without the Ford fuel line. So I'm guessing I'm fine, and I'm just overthinking it.
