D&D72 wrote:And the coil packs
DanHall wrote:I thought I had the coil packs but ran into interference with the fuel rail. Where did you move them to? I was simply lowering them and it didnt work as planned. Anyone able to grab a quick picture of good spots for both the coil pack and ps res?
DanHall wrote:Thank you Viperwolf. I got the coil packs by moving down and driver. Just clears everything. Getting closer. Now that huge oil neck and then throttle body. Looks like you are running no EGR with no elbow in the intake. I didnt have EFIguy flash for no EGR but looks like that may be the way to go for clearance.
BroncoRaider wrote:Valve covers like these work if you can't get the neck trimmed enough to work: http://www.ebay.com/itm/1987-1993-OEM-F ... 2307395741
There are some out there that do not have the vertical ribs inside. Depending on which rockers you have, you might need to find a set of those or clearance a set like this.
Viperwolf1 wrote:DanHall wrote:I thought I had the coil packs but ran into interference with the fuel rail. Where did you move them to? I was simply lowering them and it didnt work as planned. Anyone able to grab a quick picture of good spots for both the coil pack and ps res?
For the PS reservoir, you just need to move it down and back a little. How far you can move it will be limited by clearance to the suction hose.
Viperwolf1 wrote:It's routed though the spacer only. Just like the fox body egr.
DanHall wrote:Viperwolf1 wrote:It's routed though the spacer only. Just like the fox body egr.
Can you give me some details on your set up? I'm assuming you are running a fox body EGR valve which, if I am reading the wiring correctly, means that you simply left the wiring at the solenoid to open and close without worrying about the valve position indication. The Explorer is looking at dP across an orifice in the EGR tube with a DPFE sensor for valve position. So I should be able to just fab a little piece to cover the hole for the position switch on a foxbody EGR valve. Will the valve mount directly to the Explorer EGR tube?
