by pgilbeau » Mon Oct 17, 2016 1:50 pm
I am assuming this is between the master cylinder and proportioning valve which as you described splits the lines. Most local parts stores probably don't have a specific line for your vehicle. The other options are buy the materials and make one or to try an online vendor like Toms Bronco Parts, etc. You could also see if another member has one.
