Cherokee wiper upgrade
Postby Brianut » Sat Feb 05, 2011 10:22 am
Just wondering how many of you have been out there in all this lovely weather with stock wipers?
not me.
I did the conversion and it is unreal how well they work.
And for some reason I thought there were a few years that worked but I found that it is the 1986 rear arm for sure.
I went with 14" blades and they work awesome.
Napa Auto is the only place that I found to actually have them and they were almost $30 a peice but well worth it in my opinion over stock
just thought I would pass on a few tidbits that I discovered along the way.
Brianut
Re: Cherokee wiper upgrade
Postby rdanford » Sat Feb 05, 2011 3:17 pm
Just got some from Scott recently...Had been dealing with the stocks and WOW what a major improvement!
Royce
2006 4Runner V8 Sport Edition
rdanford
Postby Rox Crusher » Sat Feb 05, 2011 6:18 pm
I bought mine off of ebay a couple years back................not sure if they are cherokee or something else................but
I went from almost no wiper contact on the glass to now they push down so hard the wiper blade can't oscillate.
Works better than nothing.
Would like to look at your set up next breakfast or whatever.
Postby ClayJ » Sun Feb 06, 2011 10:59 am
I did the wiper upgrade 4 months ago, along with upgrading to the combo radiator overflow/wiper reservoir upgrade. Being able to get allot of fluid on the windshield and good wipers to clean them it's amazing.
I bought my wipers from autozone and advance auto. They only carry 1 of these at a time because it is a rear windshield wiper.
ClayJ
Postby Brianut » Sun Feb 06, 2011 11:09 am
Vragor wrote:I bought my wipers from autozone and advance auto. They only carry 1 of these at a time because it is a rear windshield wiper.
weird thing is when I called those places they said that they could not get a rear, they were no longer available???
Oh well napa had them in town and available to ma at my local store by the end of the day.
Rox: for sure you can check them out I am hoping to be at the next Bfast and swing by for some of the bumper build.
Brianut
Postby BFD305 » Sun Feb 06, 2011 11:10 pm
I just pulled another pair last time I was out at Anderson's. Still need to shorten them, but if anyones interested let me know.
Jonah says they are great.
BFD305
Images: 5
Postby ZOSO » Mon Feb 07, 2011 8:16 am
Im ready to do this. After driving around yesterday with all the splash back something needs to be done.
Postby Palmer72bronco » Mon Feb 07, 2011 8:36 am
worth their weight in gold love the conversion, just wish i could get my sprayers to work with my intermittent wiper switch. not sure what i did wrong
Palmer72bronco
Postby Colorado75bronc » Sun Feb 20, 2011 10:59 am
i just finally did mine and my dads yesterday, and im loving it, you don't have to use a rear blade, just a 14" blade for a pin style mounting, advanced auto parts, checker, napa, and all the auto parts stores usually have mutiple blades in stock
Colorado75bronc
Postby Colorado75bronc » Sun Feb 20, 2011 11:05 am
and i believe the arm can be off of a box cherokee all the way up to like 96 atleast, just check that the spline drive is the same size hole and mounting style
Colorado75bronc
Postby Brianut » Sun Feb 20, 2011 12:05 pm
Colorado75bronc wrote:and i believe the arm can be off of a box cherokee all the way up to like 96 atleast, just check that the spline drive is the same size hole and mounting style
not sure exactly what years but I looked at a bunch of early nineties and they were all too big of splines.
researched and found 86 as a for sure year. that is what I went with and it works.
Brianut
Postby cracker » Wed Feb 23, 2011 3:52 pm
Did mine years ago w/ the rear wiper arms off of the Cherokee. Great thing is that the rear arms also have the squirter nozzle attached. I ran the lines into the cab and then out to the wiper arms. Alot better than the factory spray pattern.
1-1966 Bronco
1-1967 Bronco
1-1969 Bronco
2-1973 Broncos
And a couple even run.....
cracker
Postby Colorado75bronc » Wed Feb 23, 2011 9:44 pm
i grabbed my 4 arms off of trucks ranging from 88-94, i know that the caravans and the grand cherokees were bigger splines but every box cherokee was correct i saw
Colorado75bronc
Postby Entourage » Tue Mar 08, 2011 9:32 am
How much are you guys into the Cherokee upgrade total?
Wild Horses has an upgrade hit for $55.00 so with the entrance fee to JY, time, fuel, buying the parts, blades, etc. this may be an easier way for about the same cost. I purchased the kit for convenience and the flip forward feature but mostly becasue I am fairly sure I broke my original wipers getting them off my truck lol
http://www.wildhorses4x4.com/product/Ar ... iper_Parts
Postby Brianut » Tue Mar 08, 2011 9:44 am
all new stuff I believe I am into it 65-70 IIRC.
so probably about the same when you consider shipping from WH.
Brianut
Postby BFD305 » Tue Mar 08, 2011 11:07 am
I believe the WH ones you are looking at are still stock replacements. Still not going to have good pressure to the blades.
Under $20 for the cherokee upgrade at the JY.
BFD305
Images: 5
Postby Colorado75bronc » Wed Mar 09, 2011 7:43 pm
20 bucks for 2 arms, and whatever the blades cost, 6-15 bucks a blade, and 1 dollar to get into the junkyard
Colorado75bronc
Postby BFD305 » Thu Mar 10, 2011 9:38 am
I have a set of arms shortened and ready to install (no blades). Does $25 sound fair? Let me know if anyone is interested.
BFD305
Images: 5
Postby Justin » Thu Mar 10, 2011 10:12 pm
I'll take'em. Are you going to the breakfast?
Postby BFD305 » Sat Mar 12, 2011 6:12 pm
I should be able to make it. i get off duty that morning and can swing by on my way home. I have another set i will get ready this week if anyone else needs a set.
BFD305
Images: 5
