408 Stroker Build
408 Stroker Build
Postby pgilbeau » Thu Mar 02, 2017 10:25 pm
Picked up a running roller 351W from a wrecked 95 F-150 and plan to build it into a 408. Its going to be a slow build because its been about forever since I have built a motor and I plan to swap it into the Bronco next winter. The only plans I have currently are the size and that I plan to ditch the factory fuel injection and run my current Fitech EFI. Going to be starting the disassembly process and start researching options for internals, cam, etc.
pgilbeau
Re: 408 Stroker Build
Postby landshark » Fri Mar 03, 2017 8:09 am
pgilbeau wrote:Picked up a running roller 351W from a wrecked 95 F-150 and plan to build it into a 408. Its going to be a slow build because its been about forever since I have built a motor and I plan to swap it into the Bronco next winter. The only plans I have currently are the size and that I plan to ditch the factory fuel injection and run my current Fitech EFI. Going to be starting the disassembly process and start researching options for internals, cam, etc.
where did you pick up the 351w? do you mind sharing how much it was? looking for one myself.
Postby pgilbeau » Fri Mar 03, 2017 11:29 am
landshark wrote:where did you pick up the 351w? do you mind sharing how much it was? looking for one myself.
I picked it up from Dan's Auto Salvage in Colorado Springs, it is actually down the street from Don Allison's yard. A mutual friend linked me up with Dan and I was able to go see it running in the truck before they pulled it. I paid $400 for it complete (not sure if that was a good deal or not), but I think he normally charges $550-600. I don't know what he still has because it seems like he is scaling back, he sold the two lots by Don's but he still has a couple more lots.
pgilbeau
Postby Justin » Fri Mar 03, 2017 7:00 pm
That was a decent deal for a roller.
Postby landshark » Sat Mar 04, 2017 9:10 am
Thx. That is a decent price.
Postby airbur » Thu Mar 30, 2017 9:37 am
How's the build going?
airbur
Postby pgilbeau » Mon Apr 03, 2017 5:00 am
airbur wrote:How's the build going?
It really hasn't gone beyond starting to strip off the front dress and fuel injection. Got too many other priorities like finishing my last semester of school and getting the Bronco back on the road. Should be back on this after graduation.
pgilbeau
