I finished reassembling my 4x4x2 box and now there is a tight spot when rotating the input shaft (using vice grips on input shaft). I can push through it, but it doesn't seem right. After about 1/2 a turn it loosens up and rotates freely to stop, left or right.
Its like the sector shaft is bent or something. The worm gear spins freely & the sector shaft spins freely. But put them together and something seems wrong.
I only replaced the input shaft seal on the valve assembly/worm gear, sector shaft seals & spacers, and the orings where the valve assembly & sector shaft seal to the box. I didn't break into the worm gear or do the teflon seals.
