EFI Air Filters
EFI Air Filters
Postby TOOLMAN » Thu Mar 23, 2017 8:41 am
I'm trying to find an alternative to ordering my air filter through BC Broncos. Searching a little this morning and found this one:https://www.aemintakes.com/search/product.aspx?Prod=21-202BF
Any opinions? I wanted something maybe a little shorter and one that had a number that I could cross reference to something! i obviously wanted to stay away from the oily filters.
TOOLMAN
EFI Air Filters
Postby landshark » Thu Mar 23, 2017 12:56 pm
Iam just using a generic cone filter but it has a opening at the end and sides. Like this one. https://www.ebay.com/itm/331822698357
After reading a ton I didn't see much of a difference between the expensive ones or cheaper ones. I use a heavier more dense mesh one on the 69 due to it having open fender wells and being a more traditional circle up top air filter. I clean it a few times a year.
Re: EFI Air Filters
Postby Jesus_man » Thu Mar 23, 2017 1:48 pm
I've used AEM dry-flow filters in the past and I recommend them. I like that they are cleanable and do not require the proper dosage of oil to filter the air. I think what you linked to would be just fine!
Re: EFI Air Filters
Postby darkmagus » Thu Mar 23, 2017 6:08 pm
I've been looking for one too. I'm probably going with something like this. Just wish it didn't have green foam.
https://www.amazon.com/dp/B009NM7UGI/re ... 1ybVB4YM1Y
darkmagus
Re: EFI Air Filters
Postby Justin » Thu Mar 23, 2017 6:16 pm
I wouldn't run foam. They degrade over time and get sucked into the engine. The AEM dry flow is a great choice.
Re: EFI Air Filters
Postby TOOLMAN » Fri Mar 24, 2017 6:17 am
Thanks for the responses fellas....parts on order.
TOOLMAN
