Show me your computer mounts
Postby Jesus_man » Fri Apr 07, 2017 8:01 am
I need to do something about mine! I am tired of it rattling around behind the hole that was intended to be a glove box. Would LOVE to see what you guys have done and glean some ideas!
Re: Show me your computer mounts
Postby D&D72 » Fri Apr 07, 2017 10:00 am
this box is out of an escape. easy to remove from the donor vehicle.
D&D72
Postby Jesus_man » Fri Apr 07, 2017 11:01 am
Hmm, and the computer slides on there? Looks like a nice piece!
Postby phyler » Fri Apr 07, 2017 11:19 am
The Escape box is what EFI Guy recommends. He helped me pull one for when I do my swap.
phyler
CCB Admin
Postby Jesus_man » Fri Apr 07, 2017 12:21 pm
Looking at google pics, looks like it's center of the cowl and comes out with two screws?
Sounds like some explorers have the same? Are there good model years to get these from?
Postby phyler » Fri Apr 07, 2017 1:03 pm
Jesus_man wrote:Looking at google pics, looks like it's center of the cowl and comes out with two screws?
The Explorer is a PITA to get the box out of. Look for the Escape. The Explorer is sealed in really well and I've heard people say they used a Sawzall to get them out. The Escape box is like 2x 8mm bolts to remove.
phyler
CCB Admin
Postby ZOSO » Fri Apr 07, 2017 3:45 pm
Yup the escape box here also.
Postby Justin » Fri Apr 07, 2017 6:21 pm
The Explorer boxes are easy. I pulled one in the yard in about 3 minutes last weekend. It was from a late 90s
Postby EFI Guy » Fri Apr 07, 2017 10:49 pm
JD, your Mustang harness is set up to put the PCM in the cab. So one that mounts it in the firewall isn't going to work for you. Also, I'm not sure how well an early EEC-IV PCM will fit in an EEC-V enclosure. They are similar in size but not exact. I would look for something from a PRE-96 ford car that was designed to mount it in the cab.
The Escape box in the diagram is a later PPC type (note the 3 connectors instead of 1) , those boxes are not a close match to the EEC computers at all. The Escape box to use with an Explorer swap will be PRE-2004 ish.
Justin, yours is an Escape box. The Explorer box is a nightmare to remove.
EFI Guy
VENDOR
VENDOR
Postby Justin » Sat Apr 08, 2017 6:09 am
Ah, then thanks for the correction. (Applies palm to face)
Postby Jesus_man » Sat Apr 08, 2017 10:36 am
EFI Guy wrote:JD, your Mustang harness is set up to put the PCM in the cab. So one that mounts it in the firewall isn't going to work for you. Also, I'm not sure how well an early EEC-IV PCM will fit in an EEC-V enclosure. They are similar in size but not exact. I would look for something from a PRE-96 ford car that was designed to mount it in the cab.
Ok, now to find time to head to the pick-n-pull, or perhaps just make a clam shell type something...
Postby Gunnibronco » Sat Apr 08, 2017 12:56 pm
I saw a post on FB, that BC Broncos had a computer mount that put it on the gas pedal bracket like the one I made.
Postby Jesus_man » Sat Apr 08, 2017 4:29 pm
This?
https://store.bcbroncos.com/products/ef ... ord-bronco
I wish the picture were better!
Postby Gunnibronco » Sat Apr 08, 2017 4:55 pm
Jesus_man wrote:This?
The description is worse than the picture.
It probably is it. The mount was mentioned in a comment, that it came with the EFI kit they bought from BCB. There was no picture on FB either.
