351 ARP head studs. Question?
Postby cpldavis37 » Fri Apr 28, 2017 6:45 pm
So I was putting in my head studs and noticed that some go in further than others. Some have a few threads showing. The instructions say to go hand tight. How far should they thread in and how tight should they be?
TJ
F. Scott Fitzgerald
cpldavis37
Postby Kinder » Sat Apr 29, 2017 7:41 am
Hmm, I'm not quite sure I understand the question. Hand tight until they are all in and then they'll need to be torqued in the correct sequence and to the current torque spec.
Edit: now I see, studs not bolts. Are there instructions to follow, pretty sure you still need to tighten the studs to a minimum spec, likely by locking two nuts together or if the studs had a hex end, which a lot do. You may also want to use a tap and chase the threads in the block to confirm they are all clean and the depth is the same.
Re: 351 ARP head studs. Question?
Postby cpldavis37 » Sat Apr 29, 2017 9:08 am
Thanks for the advise Kirk and Phil. I'll tap those tonight and clean them out.
TJ
F. Scott Fitzgerald
cpldavis37
