EFI MAF
EFI MAF
Postby Justin » Sat Apr 29, 2017 9:19 am
What are you EFI people using for a MAF housing? I can adapt the plastic housing from the explorer to a cone filter, but wanted to see if there is a better option first. Seems like the plastic might resist heat soak better, but plastic in my rig hurts.
Re: EFI MAF
Postby Viperwolf1 » Sat Apr 29, 2017 9:34 am
You can find an aluminum version of the housing on a lot of cars. Just need to make sure the size is the same. The size is listed on the MAF sensor and should be 70mm.
Re: EFI MAF
Postby ZOSO » Sat Apr 29, 2017 3:47 pm
I have a 4in aluminum housing. I wanna say its 110mm. Just need Garry to calibrate the maf transfer function for the housing. It would take a bit more tuning than that.
Re: EFI MAF
Postby landshark » Sun Apr 30, 2017 7:39 am
I have an extra aluminum MAF housing that Gary gave me. I just need the MAF itself off of it but your welcome to the housing if it works for the explorer stuff.
Re: EFI MAF
Postby Justin » Sun Apr 30, 2017 7:47 am
Sweet! Thanks! I'll take you up on that.
