Post-lift issue
Post-lift issue
Postby laffycaffi » Mon May 08, 2017 8:45 am
So if you've been following along on the forum, you're probably noticing that I'm a total amateur trying to lift my bronco. :)
So I replaced the bushings, installed the 2.5 Wild Horses lift... and now I'm noticing that the wheel on the driver's side extends out a noticeable amount compared to the passenger side. Any thoughts or ideas?
Thanks
laffycaffi
Re: Post-lift issue
Postby TOOLMAN » Mon May 08, 2017 9:16 am
After lifting, the stock track bar/mounts will pull the axle to the driver's side. You will need to do a either a adjustable track bar or a track bar lowering/raising bracket or both.
Maybe someone else can explain a bit more geometrically.
TOOLMAN
Re: Post-lift issue
Postby Digger » Mon May 08, 2017 9:22 am
Yes, with a lift the axle will swing to the driver's side. If you have not extended your bump stops, you should leave the track bar alone. It is important that the suspension hits the bumpstops squarely at full compression. Changing track bar length will alter where the bump stops impact the frame.
Ideally you should install a track bar riser on the axle and adjust bump stop height as needed. However a track bar riser or drop bracket will alter steering geometry too, so be prepared to deal with that.
Re: Post-lift issue
Postby laffycaffi » Mon May 08, 2017 10:15 am
So I need http://www.wildhorses4x4.com/product/Trac_bar_riser/fabricatorparts
Regarding the altered steering geometry, what's the solution to that? Bring it in for alignment or something more involved?
Shoot, I didn't realize I was signing up for this when I decided to add 2.5 inches.
Digger wrote:Yes, with a lift the axle will swing to the driver's side. If you have not extended your bump stops, you should leave the track bar alone. It is important that the suspension hits the bumpstops squarely at full compression. Changing track bar length will alter where the bump stops impact the frame.
laffycaffi
Re: Post-lift issue
Postby mickphatmac » Mon May 08, 2017 10:55 am
Try turning your Bumper right side up... Maybe that will help the geometry!??? :laughing2:
Just Kidding, I flunked Geometry and had the same thing happen on my 3.5" lift!!!
Images: 14
Re: Post-lift issue
Postby laffycaffi » Mon May 08, 2017 11:48 am
Digger wrote:Ideally you should install a track bar riser on the axle and adjust bump stop height as needed. However a track bar riser or drop bracket will alter steering geometry too, so be prepared to deal with that.
Also, how urgent is this? For example, do I need to avoid driving until I get this done or can I drive it around. I'd imagine it will be bad for tread, but what are other dangers? It's going to bother me regardless, so I'll tackle this soon enough, but wondering how bad it is to drive as is.
laffycaffi
Re: Post-lift issue
Postby TOOLMAN » Mon May 08, 2017 12:26 pm
laffycaffi wrote:So I need http://www.wildhorses4x4.com/product/Trac_bar_riser/fabricatorparts
I think that will work. And I think you can use the stock track bar with that. I would recommend changing the track bar bushings while you have it out. I used a lowering bracket that attaches to the other side on the frame with an adjustable track bar...but that was before they came out with this.\
You should always take your truck in for alignment after your lift is done!
It should be okay to drive as is...I don't think you'll hurt anything (following alignment, of course).
TOOLMAN
Re: Post-lift issue
Postby phyler » Mon May 08, 2017 12:29 pm
Not a big deal. Lot's of folks do the 2.5" lift and then don't do the track bar drop bracket or riser. Get the toe aligned (not super hard to get close in the garage) so you don't wear the tires out too fast. You'll be ok.
phyler
CCB Admin
Re: Post-lift issue
Postby Digger » Mon May 08, 2017 8:51 pm
It will drive okay the way it is after an alignment, so don't feel like you need to throw a bunch more parts at it. If you decide to correct the track bar geometry, you need to correct the entire suspension, which includes the steering. The easiest way to do this is a drop pitman arm. The main thing is to have the track bar and steering drag link be the same length and same angle to avoid bump steer.
