rooster wrote:So the zf swap for me has been a constant battle. I swapped it about a year ago from a guy in cheyenne. Guy said it was in great shape and the price was decent so I proceeded to take it and put it in my bronco. The clutch that I had at the time was an old 3 finger style but was bassicly brand new so I went with it. Well I had several issues on was what was supposed to be a great test drive, first off I had grinding issues on pretty much every gear. And then the clutch would grab bassicly as soon as you let up on it which is super annoying and makes it hard to shift. My uncle and I rebuilt the tranny. I also bought a new slave and master cylinder and got it all bled . Put the tranny back it and still the clutch will only disengage when completely pushed in, and grabs as soon as you release it even a tiny tiny amount. So I thought I had a clutch issue so I took it out again and put a new clutch in it, if I remember right it was for a late 80s early 90s f250 with a 5.8l . Put the clutch on , re bled the slave and line which no air came out... put it back together and STILL the clutch only releases if you push it all the way completely in, and grabs hard after letting it out the smallest amount. So in the middle of my axles swap I decided I would pull it out yet again and try to fix it. It's like the slave needs to be spaced out... something is wrong. Forgot to mention I also got a new flywheel for it for a early 90s 5.8l.
Any suggestions? Ideas? I am so frustrated with this thing and it needs to be fixed now cause I'm not going to take this thing out again unless I absolutely have to. The way it is now is super annoying and hard to shift. Not to mention hard on the clutch and the whole drive train.
Thanks
rooster wrote:Also the slave and master I bought were for a early 90s pickup with a 5.8l , which should be a zf tranny the line was the original that came with the transmission
rooster wrote:My pedal is nice and firm, but I have very little throw it seems like in my master cylinder before it bottoms out.
rooster wrote:I bought all the parts at orielys ,
I assumed the same thing thinking that maybe something was getting bound up on the pedal so I actually made it adjustable, but it is still bottoming out inside the master and seems limited in travel. I will post some pictures soon. Out of town at the moment
rooster wrote:It seems that all the parts that I have for the zf , slave, master, line seem to be correct. I am wondering if maybe there is a difference in flywheel thicknesses, I am running an explorer 5.0 and I bought a flywheel for a 90s ford pickup with a 5.0 so I would have the the right imbalance. And the clutch is for a 5.8l and it's an 11" with finger style pressure plate. My brother works for ford so I will see if he can get me a decent deal on a Motorcraft slave.
rooster wrote:Do you think It's possible that I got a slave for a m5OD for some reason? Or would this even bolt up to a zf5
I'm trying to think of everything
Digger wrote:You mentioned that your MC does bottom out, but is the piston returning all the way to the "home" position?
- What's your pedal ratio? (Pedal to pivot distance / MC rod to pivot distance)
When I installed mine, I had to make sure the pedal ratio was set so that the MC had full travel, then put a travel limiter on it to prevent damage. This way the clutch has maximum travel.
Justin wrote:Digger wrote:You mentioned that your MC does bottom out, but is the piston returning all the way to the "home" position?
Any tips on how to do this? I'm planning to replace the stock clutch pedal with a brake pedal, but an not sure if the stock spot for the linkage will give the right throw.
