I need to order my driveshafts & then finalize my pinon angle.
With my seats, cage, top, bumper, spare tire, etc (not a full tank of gas) installed I'm sitting at about a 3" lift (9" from rear axle to frame).
With an extra 275-300# in the rear of the truck. I drop about .5" I figure the extra weight is close to what I'd be carrying in tools, supplies, camping gear, dogs, etc on a trail run. I'd like to end up around the same lift as when I started this debacle, 3.5".
Should I add a .5" lift block? or 1"? I'm thinking .5", I can probably get some .5" flat stock and make it myself & weld it to my spring perches before I set my pinion angle.
The standard go-to measurement for a 3.5" lift would be 9.5" frame to axle, but is that fully loaded or unloaded? I didn't measure where mine was at before I took everything apart. If someone can take a measurement of their 3.5" lift and let me know where it sits, I'd appreciate it.
